| New Reply |
differential equation y(x)''=f(y(x)) |
Share Thread | Thread Tools |
| May21-12, 01:46 PM | #1 |
Hi,
simple quetion, as you can see in the title. How can I solve differential equation y(x)''=f(y(x)) I know I can write first derivative like dy/dx. But how can I write second derivative in such form? If it would be y(x)'=y, then it can be writen dy/dx=y => (1/y)dy=(1)dx => I can integrate ln(y)+C=x => its clear from now on I need some similar solution for situation when I have second derivative on the left side and some function consisting just y(x) (not x itself) on the right. Thanks for helping |
| May21-12, 02:15 PM | #2 |
| May22-12, 03:26 AM | #3 |
Hmm, chain rule.I found it at wikipedia,but cant understand it.
I understand equation y''=dy'/dx, but not y''=y' dy'/dy. Could you show me some easy example, like y''=2y^2, or y''=y^2 -y ? |
| May22-12, 05:03 PM | #4 |
What tiny-time is referring to is often called "quadrature"- you'll see why in a moment. The crucial point is that "x", the independent variable does not appear explicitely in the equation y''= f(7).
If you let u= y', you can write [tex]\frac{d^2y}{dx^2}= \frac{d}{dx}\left(\frac{dy}{dx}\right)= \frac{du}{dx}[/tex] We can then say , using the chain rule, [tex]\frac{du}{dx}= \frac{du}{dy}\frac{dy}{dx}= u\frac{du}{dy}= f(y)[/tex] which is a separable equation: [tex]u du= f(y)dy[/tex] The left side is, of course, [itex](1/2)u^2[/itex], the reason for the name "quadrature". we have [tex](1/2)u^2= \int f(x)dx[/tex] so [tex]\frac{dy}{dx}= u= \sqrt{2\int f(x)dx}[/tex] [tex]y= \int^x \sqrt{2\int^u f(t)dt} du[/tex] Of course, if f(y) was not a "nice" function to begin with, those integrals may be difficult to do! |
| Jun20-12, 02:45 PM | #5 |
udu=f(y)dy The left side is, of course, (1/2)u2, the reason for the name "quadrature". we have (1/2)u2=∫f(x)dx "" DIdn't you change y for x in this part? |
| Jun23-12, 02:01 AM | #6 |
Simple manipulation of left hand side of the equation will solve this
d(dy/dx)/dx= dy'/dy * dy/dx Moving the 1/dy factor to the right hand side, we get y' dy' = f(y) dy Integrating this will give us (1/2)y'^2=F(y) (F'(y)=f(y)) Rearranging, we get dy/dx=[2F(y)]^1/2 And of course, the second order diff eq. is reduced to a simple ODE. Using the method of separation of variables, we obtain x=integral{dy/[2F(y)]^1/2} |
| Nov24-12, 01:02 PM | #7 |
For the same general equation, how can i solve
y''(x)=a*sin(y(x)) ; a is a constant I think it would be a numerical method. |
| Nov24-12, 06:27 PM | #8 |
hi etpatati1! welcome to pf!
![]() ![]() (or use the chain rule … y'' = dy'/dx = y' dy'/dy) |
| Nov25-12, 01:46 AM | #9 |
| New Reply |
| Tags |
| differential, equation, y''=f(y), y(x)''=f(y(x)) |
| Thread Tools | |
Similar Threads for: differential equation y(x)''=f(y(x))
| Use the differential operator to solve this differential equation | Calculus & Beyond Homework | 1 | ||
| General equation for change of variable in a differential equation | Differential Equations | 4 | ||
| Simple Differential Equation (Ordinary Differential Equation) | Differential Equations | 7 | ||
| Expressing magnetostatic equation as a partial differential equation | Classical Physics | 0 | ||
| Laplace's Equation and Seperation of Multivariable Differential Equation | Introductory Physics Homework | 2 | ||
