Change in momentum of baseball being struck
The discussion focuses on calculating the change in momentum of a 0.33 kg softball struck by a bat. The initial velocity of the ball is 14 m/s at a 50° angle below the horizontal. Two scenarios are analyzed: (a) the ball exits the bat with a velocity of 15 m/s vertically downward, and (b) it exits horizontally back toward the pitcher. The momentum is calculated using the formula P = M * V, and the magnitude of the change in momentum is determined using vector subtraction and the Pythagorean Theorem.
  • Understanding of momentum and its vector representation
  • Familiarity with trigonometric functions for resolving vectors
  • Knowledge of the Pythagorean Theorem for calculating magnitudes
  • Basic physics concepts related to collisions and motion
  • Study vector decomposition in physics for better understanding of momentum
  • Learn about the conservation of momentum in collisions
  • Explore the effects of angle on projectile motion
  • Investigate real-world applications of momentum changes in sports physics
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators seeking examples of momentum calculations in sports contexts.
Zach Lunch
A 0.33 kg softball has a velocity of 14 m/s at an angle of 50° below the horizontal just before making contact with the bat. What is the magnitude of the change in momentum of the ball while it is in contact with the bat if the ball leaves the bat with a velocity of (a) 15 m/s, vertically downward, and (b) 15 m/s, horizontally back toward the pitcher?
→P=M*→V
Find the Vector for momentum before hitting the bat .33<14*cos 50, 14*sin 50>
Subtract vector for each case. a) subtract .33<0,-15> b.) subtract .33<-15,0>
Then use Pythagorean Theorem to get magnitude sqrt(x^2 + y^2) for each case.
Zach Lunch said:
A 0.33 kg softball has a velocity of 14 m/s at an angle of 50° below the horizontal ...
The angle is 50° below the horizontal. The vertical component of the original momentum has to be negative.
ehild
