The probabililty of 3 rolls of dice and get two 6's
  • Context: Undergrad
  • Thread starter Thread starter Philip Wong
    Dice
The discussion revolves around calculating the probability of rolling two sixes in three rolls of a die. Participants explore various methods to arrive at the probability, including intuitive approaches and formal mathematical techniques. The scope includes theoretical reasoning and mathematical reasoning related to probability.
  • One participant proposes three methods to calculate the probability: a direct multiplication approach, a binomial equation, and a Bernoulli equation, each yielding different results.
  • Another participant critiques the first method for only considering one arrangement of the outcomes and suggests that it should account for all possible arrangements of the two sixes.
  • A different approach is suggested, focusing on the converse probability of not rolling any sixes and using that to find the desired probability.
  • There is a discussion about the correct application of the Bernoulli formula, with one participant expressing uncertainty about the interpretation of their previous calculations.
  • Clarifications are made regarding the interpretation of the formulas, particularly in relation to the number of sixes rolled.
Participants express differing views on the correctness of the various methods proposed. There is no consensus on which method is definitively correct, and multiple competing views remain throughout the discussion.
Some participants note potential misapplications of probability formulas and the need for careful consideration of arrangements in calculating probabilities. There is also mention of the independence of dice rolls, which is assumed but not explicitly confirmed.
This discussion may be useful for individuals interested in probability theory, particularly in the context of discrete events like dice rolls. It may also benefit those looking to understand common pitfalls in applying probability formulas.
Philip Wong
I was asked to help someone to work out the probability above. It was more than a year since I done similar questions and thing do get rusty... So I hope to work it out here and get point out where I did wrong before I show that person the correct answer.
Intuitively there is three ways I came up to solve the problem, which apparently gave different answers. So it's either one or two or all three methods are wrong. Methods I came to mind are:
1) 1/6 * 1/6 * 5/6 = 0.023 -> this is the first idea came to my mind, since there is only 3trials and the probability of getting a 6 is 1/6, so I use the multiply rule to times things together. The results seems rather small, so I doubt this is the correct method.
2) 3C2 * 1/6 * (5/6)^2 = 0.347 -> I got this by using the binomial equation
3) 3C2 * 1/6 * 5/6 = 0.416 -> I got this by using the Bernoulli equation i.e. n*p*q. where n is the number of all possible outcomes, p is the probability of getting a 6, and q is the probability of not getting a 6.
Please check which methods I used was correct, and if neither of them was correct please suggest a way to work this out.
Hi Philip!
The first one is wrong because you just consider the case [6, 6, x], you need to consider also the cases [6, x, 6] and [x, 6, 6], that is [itex]3 \cdot 0.023.. \sim 0.069[/itex]
The second case is wrong because you raised to the power of two the wrong probability
[itex]{3\choose 2} \cdot (1/6)^2 \cdot 5/6 \sim 0.069[/itex] which also explains why you also got wrong the Bernoulli formula.
Good luck getting "unrusted"! :wink:
usually this is solved by considering the converse probability: what's the probability of not getting any 6's in three rolls and then use the 100% - P to get the probability that you want.
Hey Philip Wong.
The best way I think to do this is to use a binomial distribution with 3 trials where one state corresponds to rolling a 6 and the other not rolling a 6. Each dice roll is independent (assumed) and has the same probabilities. In this case p = 1/6 and 1-p = 5/6
This means your probability is given 3C2 p^2 x (1-p) = 3C2 x 5/192 = 15/192
You can visualize this by drawing a tree diagram of the events on paper. Use two events: a 6 for one and a non-6 for everything else and then you will get a tree with 8 possibilities with three levels of depth.
chiro said:
Hey Philip Wong.
viraltux said:
Hi Philip!
Hi guys,
Thanks for your help. So what I should do if I were to keep using the Bernoulli formula (n.p.q) what I should really do is:
[itex]{3\choose 2} \cdot (1/6)^2 \cdot 5/6[/itex]
I knew I had either misplaced or missed something in the formula.
So if I used what I've provided before, i.e. [itex]{3\choose 2} \cdot (1/6) \cdot (5/6)^2[/itex] what it really meant was, the probability of only getting one 6 out of the three dice roll right?
thanks
thanks
Nope, it would be the probability of getting anything but 6 in both dices.
  • · Replies 16 ·
  • · Replies 41 ·
  • · Replies 42 ·
  • · Replies 32 ·
