Dif.eq. with trigonometric functions involving y
The discussion revolves around solving a differential equation involving trigonometric functions, specifically the equation dy/dx + (e^x)*Sec(y) = Tan(x). Participants explore methods for finding an integrating factor and transforming the equation into a solvable form.
  • Homework-related
  • One participant expresses confusion about solving the differential equation and seeks assistance, mentioning an integrating factor of e^-ax and questioning the nature of "a".
  • Another participant welcomes the newcomer and encourages them to share their full calculations to identify any errors.
  • A participant describes their attempt to manipulate the equation into a linear form using the ArcSecant function but finds it complicated and unclear on how to proceed.
  • One participant challenges the approach taken by another, suggesting that the integrating factor is not simply e^-ax for real a and provides a different formula for determining the integrating factor based on the equation's structure.
Participants do not appear to reach consensus on the correct method for solving the equation, with differing opinions on the integrating factor and the approach to take.
There are unresolved assumptions regarding the value of "a" in the integrating factor and the conditions under which the proposed methods are valid. The complexity of transforming the equation into a linear form is also noted.
mausmust
I tried to solve it but confused. Pls. help me to solve this equation:
dy/dx + (e^x)*Sec(y) = Tan(x);
(hint: integrating factor is e^-ax, and a is unknown, a ε ℝ, find it, solve the equation)
Thnx.
welcome to pf!
hi mausmust! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
show us your full calculations, and then we'll see what went wrong, and we'll know how to help! :smile:
Hii, thank you :)
I did:
dy + (exSec(y)-Tan(x))dx = 0
0 ≠ exSec(y)Tan(y) (∂N/∂x ≠ ∂M/∂y) So, we need an integrating factor. If we use e-ax;
-ae-ax = e(1-ax)Sec(y)Tan(y) appears.
Shouldn't be "a" is a real value? Also;
I tried to modify equation with ArcSecant function to become a linear equation with this form;
dy/dx + P(x)y = Q(x)
but it went more complicated. How can we solve it?
I don't think you're doin' that right. Also, don't use capitals letters for the trig functions. If you have:
[tex]Mdx+Ndy=0[/tex]
and:
[tex]\frac{1}{N}\left(\frac{\partial M}{\partial y}-\frac{\partial N}{\partial x}\right)=f(x)[/tex]
then the integrating factor is:
[tex]u=\exp\left(\int f(x)dx\right)[/tex]
but that's not just [itex]e^{-ax}[/itex] for real a.
  • · Replies 28 ·
  • · Replies 17 ·
