Rate of change of quantum levels (emission spectra) at 333 cm sized atoms
The discussion centers on the rate of change of quantum levels during atomic transmutation, specifically regarding the emission spectra of newly formed atoms. It is established that while eigenstates may change simultaneously, wave functions do not, and measurement of spectral lines requires time comparable to the atom's size due to energy/time uncertainty principles. The concept of Rydberg atoms is introduced, highlighting that while they can exhibit larger radii, these are still in the micrometer range, not the 0.3 meters mentioned. The conversation emphasizes the complexities of quantum mechanics and the implications of measurement in atomic physics.
  • Quantum mechanics fundamentals
  • Understanding of atomic transmutation
  • Familiarity with spectral lines and emission spectra
  • Knowledge of Rydberg atoms and their properties
  • Research the principles of atomic transmutation and its effects on quantum levels
  • Study the energy/time uncertainty principle in quantum mechanics
  • Explore the properties and applications of Rydberg atoms in experimental physics
  • Investigate the mathematical models of wave functions and eigenstates in quantum theory
Physicists, quantum mechanics students, and researchers interested in atomic behavior and the implications of measurement in quantum systems.
beanangel300
Hi there, my comparatively ignorant mind is wondering,
When an atomic transmutation occurs all of the quantum levels of the new atom also change
1) what is the actual rate of this change? would a nonplayer "observer photon" passing near the suddenly different element note the quantum level possibilities of the new element radiating outwards from the nucleus at the speed of light
or
2) would all the quantum levels (spectral lines) change simultaneously, absent any "chonodistance" effects as a result of the absolute possibilities of the new nucleus.
further, at a big transmuted atom with lots of electrons, when all the electrons move to the new quantum levels permitted at the new nucleus what are the energy equations that say where this (variously) extra or required energy comes from. also, does the new spectral level shifting of dozens of electrons have a computational energy meaning? do different transmutations create very different "numbers of possible quantum level positions per each electron (possibly factorial)" that actually suggest fairly large numbers of discrete states as a result of a fairly simple fissionI have read that at deep space the radius of a hydrogen atom is about .3 meters, so apparently there is a very wide area of nstantaneuity. Does that suggest anything about the nteraction of lots on non or minimally nteracting observer particles with a 333 cm area of sudden quantum difference?
I have no idea what you are talking about, but a hydrogen atom in space does not have a radius of .3 m. It's the same size as it is everywhere else.
While Eigenstates might change simultaneously (they are just a mathematical model of your atom), the wave functions do not (unless you follow some collapse interpretations and measure something).
In any way, a measurement of spectral lines takes a time which is at least comparable to the size of the atom. Otherwise energy/time uncertainty kills the possibility to get a meaningful energy measurement.You can produce excited states of the hydrogen atom with a large radius (rydberg atoms, but you have to do this in the lab and "large" is still of the order of micrometers, not meters.
  • · Replies 35 ·
  • · Replies 19 ·
