| New Reply |
help with work problem |
Share Thread | Thread Tools |
| May24-12, 03:13 PM | #1 |
A 2000lb elevator travels from the ground floor to the 1st floor and on to the 9th floor. At the 1st floor, a 100lb person gets off, on the 2nd floor a 110lb person gets off, on the 3rd floor a 120lb person gets off and so on and so on till the last person gets off on the 9th floor.
a) How much did the last person to get out of the elevator weigh? What was the total weight to start? b) If each floor is 10 feet in height, find the work done by the elevator. (Hint: No integrals needed). Write the Riemann Sum (in terms of i) for the work and find the numerical value of the total work done. I know for part a) there is some integration I can use to get the solution. By writing it all out I was able to conclude that the last person to get off was 180lbs, right? I'm just not certain how to conceptually get to that solution through integration...HELP! For b) I thought solving it with integrals would be the only possible way and I'm pretty stumped as to how to get the work using Riemann...or I figured I could have used the formula W=F(d) but that's confusing me as well. /: |
| May24-12, 03:53 PM | #2 |
Recognitions:
As to (b): how much work is done to reach the first floor? How much to reach the second from the first? Etc. RGV |
| May24-12, 05:50 PM | #3 |
I just wrote it all out to begin with some idea. floor 1 - 100 lb floor 2 - 110 lb floor 3 - 120 lb floor 4 - 120 lb + 10 lb = 130 lb floor 5 - 130 lb + 10 lb = 140 lb floor 6 - 140 lb + 10 lb = 150 lb floor 7 - 150 lb + 10 lb = 160 lb floor 8 - 160 lb + 10 lb = 170 lb floor 9 - 170 lb + 10 lb = 180 lb I tried to ∫ 100x from 1 to 9 but that just gave me 4,000...which is definitely not right. Then I tried to ∫ 10x from 1 to 9 and that gave me 400. I've never tried a problem like this before, that's why I'm a little lost... As to b) W=F×d And weight is a force, right? Then, each floor is 10 feet in height...so W to reach the first floor would be (the total weight of the elevator, including the people on it) × the distance (10ft)? I'm not sure if I'm headed in the right direction, but if I am correct, wouldn't I have to calculate a different force for every floor since the weight of the elevator and the people in it is constantly changing? |
| May24-12, 06:05 PM | #4 |
That's kind a strange problem. As far as (a) is concerned, you would have to assume that the pattern of weights will continue- which is NOT my experience with elevators.
Now, for constant weight, w pounds, the work done in moving up h feet is wh "foot pounds". But you are calculating the weights backwards. Initially, everyone was in the elevator. So between the ground floor and first floor the total weight in the elevator was 100+ 110+ 120+ 130+ 140+ 150+ 160+ 170+ 180+ 2000 pounds. Multiply that by the distance between the ground and first floors. Since a person weighing 100 pounds get out at the first floor, the weight between the first and second floors is 110+ 120+ 130+ 140+ 150+ 160+ 170+ 180+ 2000 pounds. Multiply that by the distance from the first floor to the second floor to find the work done there. |
| May24-12, 06:19 PM | #5 |
W=3260(10)+3160(10)+3050(10)+2930(10)+2800(10)+2660(10)+2510(10)+2350(1 0)+2180(10)+2000(10)? Giving me 269,000 ft-lbs. |
| May24-12, 06:23 PM | #6 |
You include the work done by the empty elevator going to the 10th floor while the problem talks about the elevator going to the 9th floor. In fact, there is no reason to think the building even has a tenth floor.
| May24-12, 06:27 PM | #7 |
W=3260(10)+3160(10)+3050(10)+2930(10)+2800(10)+266 0(10)+2510(10)+2350(10)+2180(10)= 249,000 ft-lbs. Right? And also, for a), assuming that the patterns of weight is constant, how would my integral look to conclude that the last person to get off the elevator was 180lbs? |
| May24-12, 10:19 PM | #8 |
Recognitions:
RGV |
| May25-12, 12:52 AM | #9 |
| May25-12, 01:11 AM | #10 |
The weights are increasing linearly, and so w(f) = 90 + 10f.
In integral form, w(f) = 90 + ∫10 with your bounds of integration being 0 to f. I can see wanting a function, but having an integral in there makes things more complicated. |
| May25-12, 08:01 AM | #11 |
Using an integral would involve assuming that people got off the elevator in pieces between floors! It will give you an approximation to the sum, not the actual sum. This problem may have been put into a pre-integration section as an introduction to the idea of Riemann sums.
You can approximate a smooth function by "piecewise" constant functions- that's the idea of "Riemann sums"- but you are trying to approximate a piecewise constant function by a smooth function. |
| May25-12, 10:17 AM | #12 |
Recognitions:
As I said before, your desire to somehow hammer the problem into a form appropriate for integration is hindering your understanding of the problem! You could, of course, formulate the problem as an integration of a discontinuous function, but the only way to _compute_ that integral would be to break it up into pieces and compute each piece separately. That would just lead you back to your starting point. RGV |
| New Reply |
| Tags |
| calculus, feet, pounds, riemann, work |
| Thread Tools | |
Similar Threads for: help with work problem
| Physics problem: Radial acceleration, forces, and work & energy problem | Introductory Physics Homework | 13 | ||
| Work and Kinetic Energy Problem involving friction hw problem, DUE SOON | Introductory Physics Homework | 1 | ||
| Work, Energy, or Work problem | Introductory Physics Homework | 3 | ||
| Work, Energy and Power (Work Problem) | Introductory Physics Homework | 9 | ||
| Homework problem- Work and energy problem | Introductory Physics Homework | 13 | ||
