Gram-Schmidt Process: Find Basis W for Polynomials P_2
  • Thread starter Thread starter Hiche
    Process
The discussion focuses on applying the Gram-Schmidt process to find an orthogonal basis for the subspace W, defined as the span of the polynomials p(x) = 1 + x and q(x) = 1 + 2x^2. The resulting basis is {b1, b2} = {1 + x, 1/2 - x/2 + 2x^2}. The inner product for this polynomial space P_2 is defined as = a_0b_0 + a_1b_1 + a_2b_2, where a_n and b_n are the coefficients of the polynomials. The dimension of W is 2, indicating that no additional linearly independent basis functions can be added without redundancy.
  • Understanding of the Gram-Schmidt process for orthogonalization
  • Familiarity with polynomial spaces, specifically P_2
  • Knowledge of inner product definitions in function spaces
  • Basic linear algebra concepts, including linear independence and dimension
  • Research the Gram-Schmidt process in detail, including its applications in higher dimensions
  • Explore the properties of polynomial spaces, particularly P_2 and its basis functions
  • Learn about inner product spaces and their significance in functional analysis
  • Investigate extensions of the Gram-Schmidt process for generating additional orthogonal basis elements
Students and educators in mathematics, particularly those studying linear algebra and functional analysis, as well as anyone interested in the application of the Gram-Schmidt process to polynomial spaces.
Hiche
The question states that we should use the Gram-Schmidt to find an orthogonal basis for W where W = span {p , q} and p(x) = 1 + x ; q(x) = 1 + 2x^2
Let [itex]\{b1, b2\}[/itex] be such a basis. Using the G-S process:
[itex]b1 = p = 1 + x[/itex]
[itex]b2 = q - proj^q _b = q - \frac{<q, b1>} { \|b1\|^2} . b1[/itex]
Is this the right way? The answer I got was [itex]\{b1, b2\}[/itex] = [itex]\{1 + x, 1/2 - x/2 + 2x^2\}[/itex]
Note that p and q belong to the set of polynomials of degrees 2 or less (i.e [itex]\in P_2[/itex]) and [itex]< , >[/itex] denotes an inner product of two components.
Also, presume I need to find further basis -- [itex]b3[/itex] -- is there a generality for [itex]bn[/itex] for example?
I haven't checked your work closely, but this is the right idea. You can check orthogonality by taking the inner product of these two functions. BTW, you didn't say what the inner product was for your space - an integral of some kind?
Again, what is the inner product you are using?
{b1, b2} is the basis for W, which is a proper subspace of P2.
The dimension of W is 2, so any basis for W will consist of two lin. independent vectors/functions. This means it is not possible to find another basis function, which is what I think you are asking. If you add a vector or function to a basis, the new addition will necessarily be a linear combination of the other elements in the set.
The dimension of P2 is 3, so a basis for this function space will consist of three lin. independent functions.
If you are asking whether the Gram-Schmidt process can be extended to find more than two orthogonal basis elements - yes, it can. I'm sure you can find an article on wikipedia about this.
Oh right. The inner product is defined on [itex]P_2[/itex] as such: [itex]<p, q> = a_0b_0 + a_1b_1 + a_2b_2[/itex] where [itex]a_ns[/itex] are the constants of [itex]p(x)[/itex] and [itex]b_ns[/itex] are the constants of [itex]q(x)[/itex].
  • · Replies 16 ·
14K
