New Reply
Find General Solution to Equation
Share Thread Thread Tools
May26-12, 01:35 PM   #1
y'' - 3y' + 2y = e2xcos x
3. The attempt at a solution
So this is a second order inhomogeneous equation.
gives λ = {2,1}
get yCF giving Ae2x + Bex
so yP = e2x(Ccosx + Dsinx)
Here is where is gets a bit fuzzy.
Subbing this into the top equation gives me 2e2x((-2D-C)cosx + (2C-D)sinx)
which is wrong, i have gone through it and am missing something can you help me find this correct expression? Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May26-12, 02:54 PM   #2
Recognitions:
Gold Membership Gold Member
Well, it depends on what method you used to find ##y_p##. Personally, i use the inverted operator technique (but there is apparently also the variation of parameters method).
Here is what i would do: Use the shift theorem to separate ##e^{2x}## (moves to the left) from ##\cos x##. $$\frac{ke^{ax}.\phi (x)}{L(D)}\to ke^{ax}.\frac{\phi (x)}{L(D+a)}$$where k=1, a=2.
From there, use the appropriate inverted operator technique on ##\cos x## which is: $$\frac{k\cos (ax+b)}{L(D)} \to \frac{k\cos (ax+b)}{L(-a^2)}$$ where k=1, a=1, b =0.
May26-12, 03:58 PM   #3
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by JoshMaths View Post
gives λ = {2,1}
so yP = e2x(Acosx + Bsinx)
Correct so far.
What are C and D? Show your work in detail, please.
ehild
May26-12, 04:03 PM   #4
Mentor
gives λ = {2,1}
Subbing into the top equation, I get e2x((-C+D)cosx + (-C-D)sinx) for the left hand side.
May26-12, 04:07 PM   #5
Recognitions:
Quote by SammyS View Post
That is correct, Sammy.
ehild
May26-12, 06:06 PM   #6
Quote by ehild View Post
Correct so far.
ehild
Yep, my mistake, C and D were in y particular but I always mix them up accidentally. It has been fixed.
Yep, this is right, i tried and i got (-C-3D)cosx +(3C-D)sinx i guess i am just not seeing it. I understand if you don't have time to write out some of the algebra manipulations but they would be useful if anyone could find a minute. If not, i'll keep working at it.
May26-12, 06:36 PM   #7
Mentor
What do you get for y' and y'' ?
May27-12, 10:26 AM   #8
I have tried with y'' + 3y' + 2y = e2xcos x
and get e2x((11C+7D)cosx + (11D-7C)sinx) which is correct so i think it was just that specific example i was having trouble with, but i understand the principle behind it better now.
May27-12, 09:31 PM   #9
Mentor
To repeat my question(s) ...
What do you get for yP' ?
What do you get for yP'' ?
New Reply
Tags
calculus, inhomogeneous, particular solution, solve
Thread Tools
Similar Threads for: Find General Solution to Equation
Thread Forum Replies
Find the general solution of a differential equation Calculus & Beyond Homework 1
Find the general solution for a nonhomogenous equation. Calculus & Beyond Homework 5
find general solution of non homogenious linear equation Calculus & Beyond Homework 6
find the general solution of a coupled differential equation: Calculus & Beyond Homework 10
Find general solution to Bessel's equation with substitution Calculus & Beyond Homework 9
