Transformer currents in primary and secondary question
This discussion focuses on the behavior of currents in transformers, specifically the relationship between primary (Ip) and secondary (Is) currents. The formulas Vs = Vp(Ns/Np) and Ip = Is(Ns/Np) are established for ideal transformers. It is confirmed that the primary current is influenced by the inductance of the primary winding, which introduces reactance that affects current flow, even when the secondary is open. Additionally, the quality of the transformer, particularly its inductance and reactance, can impact current levels significantly.
  • Understanding of transformer principles and operation
  • Familiarity with electrical formulas, specifically Vs = Vp(Ns/Np) and Ip = Is(Ns/Np)
  • Knowledge of inductance and reactance in electrical circuits
  • Basic concepts of load resistance and its effect on current
  • Study the impact of inductance on transformer efficiency and performance
  • Learn about non-ideal transformer behavior and losses
  • Explore the effects of load resistance on primary and secondary currents
  • Investigate transformer design considerations for minimizing current flow under no-load conditions
Electrical engineers, students studying power systems, and professionals involved in transformer design and analysis will benefit from this discussion.
KrNx2Oh7
I'm reviewing transformers and I have some confusion over the current
s is for secondary and p is for primary
I know that
Vs = Vp(Ns/Np)
and
Ip = Is(Ns/Np)
So when you have a load across the secondary terminal you get your current through Vs/Rload.
But does this mean for current in the primary coil, it has nothing to do with the inductance value or resistance (if I added a resistor before the inductor in the primary section)? V/Z = I does not work here?
If this is true what would the current be if I left the secondary terminal open so no current will flow. What do i use to calculate current in the primary coil? Is it affected by the inductance value then?
thanks in advance
I know that
Vs = Vp(Ns/Np)
and
Ip = Is(Ns/Np)
thanks in advance
Those formulas are for ideal transformers. There will be a current in the primary due to the load in the secondary, but there will also be a current due to the inductance of the primary winding.
It is just a coil and it has to have some value of inductance and so it has a reactance which will allow a certain amount of current to flow from the supply.
Cheap transformers are sometimes wound on inadequate iron formers and so don't have enough inductance or reactance to stop a relatively large current flowing even if there is no load.
  • · Replies 81 ·
9K
9K
  • · Replies 34 ·
