New Reply
Limits on an Integral of a semi-circle
Share Thread Thread Tools
May28-12, 03:43 PM   #1
A question asks to calculate the integral over the region R given by:
x^2 + y^2 <= 4
0 <= y <= 2
Which would be the upper half of a circle of radius 2 centred on the origin.
The integral is done in the book I have and the limits of x are given as -2 to 2, which I can understand.
Though the limits for y are given as: 0 to (4 - x^2)^0.5
I can see that they have obtained this limit from rearranging the first part of the region R.
BUT, why is the limit for y not 0 to 2. Or alternatively, if what they have done is correct, why is it not equally valid to state the limits for x are: 0 to (4 - y^2)^0.5
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May28-12, 04:09 PM   #2
When integrating over a region, we need to hit each point in the region exactly once, and no other points.
So your recipe is, for each x betwen -2 and 2, (hold x fixed and) integrate over y=0 to 2. But then you would hit all points in a rectangle, not the semicircle.
You'll hit each point in the semicircle once if, for each x between -2 and 2, you go from y= 0 to the upper circle.
If this seemed to make sense, here's some exercises to check that you understand.
Try switching order of integration, that is, for each y in between (which values?), let x runf from where to where, thus hitting each point in the region.
Another exercise. In the original limits, hold x fixed and let y vary, why do we take x goes from -2 to 2. Why not a smaller or larger region, what exactly would be wrong with that, how geometrically or by what type of value would it change the answer. (Hint: integration works if we hit each point in region exactly once, and no others.)
May28-12, 05:21 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi ZedCar!
Quote by ZedCar View Post
It is, if the y limits are -2 to 2.
You can have vertical slices of thickness dx and height √(4 - x2)
or horizontal slices of thickness dy and width √(4 - y2).
New Reply
Thread Tools
Similar Threads for: Limits on an Integral of a semi-circle
Thread Forum Replies
Double integral circle limits Calculus & Beyond Homework 6
E-field of a semi circle. Advanced Physics Homework 9
Double integral-semi circle Calculus & Beyond Homework 1
Integral of (z^2)dz around a semi-circle in the y >= 0 region. Calculus 9
Sliding Off A Semi-Circle Introductory Physics Homework 4
