New Reply
Temperature increment of polymer due to pressure in ultrasonic welding
Share Thread
May31-12, 05:37 AM   #1
Hi,
I want to do a very simplified model to try to modelize the change of temperature in ultrasonic welding of polimers.
As a starting point, I only want to simulate the change of temperature of a 1D homogeneous polymer (viscoelastic solid) when I apply a constant pressure and ultrasounds on it.
I considered two types of models:
-an energetic one using the energy of the ultrasonic wave, the impedances for the transmited-reflected energy and de absorption coeficient of the materials
-a mechanical one, considering the strain induced by the sonotrode and the resulting stress using the Voigth model. Then the work done by the material is obtained and, from this, the quantity of heat generated.
My question/problem is: how can I introduce in these models the heat generated due to the applied pressure in the solid ?
If anyone can help me, i would be pleased.
Thank you
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
New Reply
Tags
polymer processing, pressure, temperature, ultrasounds, welding
Similar discussions for: Temperature increment of polymer due to pressure in ultrasonic welding
Thread Forum Replies
Ultrasonic waves through pressure General Physics 6
Cold pressure welding General Engineering 6
Welding Thoughts (Relationship of Current and Arc Temperature) General Engineering 0
High pressure Valves - Polymer foaming Materials & Chemical Engineering 0
