First-Order Linear Differential Problem
The discussion revolves around solving an initial value problem (IVP) involving a first-order linear differential equation represented in matrix form. The participants are exploring eigenvalues and particular solutions related to the system defined by the matrix and the input vector.
  • Participants discuss the calculation of eigenvalues for the matrix and the form of the complementary solution. There is an ongoing debate about the correct approach to finding the particular solution, with suggestions for different forms of X_p being proposed.
The conversation is active, with participants questioning the correctness of their calculations and assumptions regarding the eigenvalues and the form of the particular solution. Some guidance has been offered, but there is no explicit consensus on the correct approach to finding X_p.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is uncertainty regarding the correctness of the eigenvalue calculations and the proposed forms for the particular solution.
Hiche
Solve the following IVP:
[itex]X' = \begin{pmatrix}2 & -1\\3 & -2\end{pmatrix}X + \begin{pmatrix}0\\t\end{pmatrix}[/itex] with [itex]X(0) = \begin{pmatrix}1\\0\end{pmatrix}[/itex]
The eigenvalue corresponding to [itex]\begin{pmatrix}2 & -1\\3 & -2\end{pmatrix}[/itex] is [itex]\lambda = 0[/itex]. We find that [itex]X_c = c_1\begin{pmatrix}1\\2\end{pmatrix} e^{0t}[/itex]. Now in order to find [itex]X_p[/itex], how exactly is the right way? I took [itex]X_p = \begin{pmatrix}a_1\\b_1\end{pmatrix}t[/itex] and wanted to find [itex]a_1[/itex] and [itex]b_1[/itex]. Right or wrong?
Hi Hiche! :smile:
Nooo :redface:
oh, crap! Apparently, 3 * 1 = 4 -_-
So, again, the eigenvalues are [itex]\lambda_1 = -1[/itex] and [itex]\lambda_2 = 1[/itex]. I hope this is correct. So the solution of [itex]X_c = c_1\begin{pmatrix}1\\1\end{pmatrix}e^t + c_2\begin{pmatrix}1\\3\end{pmatrix}e^{-t}[/itex].
Now about [itex]X_p[/itex]. Is my method correct (first post)?
(i'm not sure, but…) i'd be inclined to go for [itex]X_p = \begin{pmatrix}a_0\\b_0\end{pmatrix} + \begin{pmatrix}a_1\\b_1\end{pmatrix}t[/itex]
Okay, so upon a little work, [itex]X_p = \begin{pmatrix}1\\2\end{pmatrix}t[/itex] and the general solution is [itex]X = X_c + X_p[/itex]
Thank you, tiny-tim.
But [itex]X_p = \begin{pmatrix}1\\2\end{pmatrix}t[/itex] isn't a solution …
Xp' = (1,2), and Xp(0) = (0,0)
