Mathematica plot question, dsolve
  • Thread starter Thread starter kptsilva
    Mathematica Plot
The discussion focuses on solving a second-order differential equation using Mathematica, specifically the equation 2/3 a^2 b''[a] + (1 - w[a]) a b'[a] - (1 + w[a]) (1 - 3 c w[a]) b[a] with boundary condition b'[0.0001]=0. The user encounters issues with plotting the solution due to imaginary components and the need for proper boundary conditions. Key solutions include changing 'b' to 'b[a]' in the DSolve command and addressing the plotting method to ensure accurate representation of the results.
  • Familiarity with Mathematica syntax and functions
  • Understanding of differential equations and boundary conditions
  • Knowledge of plotting techniques in Mathematica, specifically LogLinearPlot
  • Basic grasp of complex numbers and their implications in mathematical solutions
  • Explore the use of DSolve in Mathematica for solving differential equations
  • Learn about boundary value problems and their significance in differential equations
  • Investigate the handling of complex solutions in Mathematica plots
  • Study advanced plotting techniques in Mathematica, including LogLinearPlot adjustments
Mathematica users, mathematicians, and researchers dealing with differential equations and their graphical representations.
kptsilva
Hey guys,
I'm using Mathematica to plot some graphs and I'm having a bit of a hard time.
First I have to solve the following equation,
Boundary condition b'[0.0001]=0
Where;
w[a_] := 2*a^(3*(1 + c))/(1 + 2*a^(3*(1 + c)));
(c=1) (c is a variable but let's consider a particular instance c=1)
a goes from 10^-4 to 1000 in a log scale.
I want to plot b[a]/b[0.0001] vs. a
I've so far written a simple code but it is with errors.
c = 1;
fun = 2/3 a^2 b''[a] + (1 - w[a]) a b'[
F[a_] = DSolve[{fun == 0, b'[10^(-4)] == 0}, b, a]
L = LogLinearPlot[Evaluate[F[a]/F[0.0001]], {a, 10^-4, 10},
PlotRange -> All];
Please can anyone help me
Two things: In your DSolve[] command, change b to b[a]. Second, if it's not plotting properly, it's for two reasons. You're using a lin-log plot to plot the answer, and the answer has imaginary components. Also, you have a second order equation with only one boundary condition. I assume that the other involves the function decaying at infinity, which Mathematica doesn't really like
I've changed b to b[a] and it works fine editing the log-lin plot command. I don't need two boundary conditions since I'm plotting b[a]/b[0.0001] so the constant cancels off. It's true, i have imaginary parts in my solution, i wonder if mathematica takes them into account for the plot
  • · Replies 21 ·
  • · Replies 18 ·
