Finding the freezing point of water at high pressures
The freezing point of water at a pressure of 32.52 bar can be calculated using the Clausius-Clapeyron equation. The equation is expressed as ln(p2/p1) = deltaHfusion/R * ((1/t2)-(1/t1)), where deltaHfusion is 6.008 x 10^3 J/mol and T1 is 273.15 K. The discussion emphasizes the importance of accounting for density changes when applying this equation, suggesting that the basic dp/dT = l/TΔv approach with definite integrals may be more appropriate for non-ideal conditions.
  • Understanding of the Clausius-Clapeyron equation
  • Knowledge of thermodynamic principles, specifically phase changes
  • Familiarity with the concept of pressure and its effects on freezing points
  • Basic calculus skills for working with definite integrals
  • Study the application of the Clausius-Clapeyron equation in non-ideal conditions
  • Learn about the relationship between pressure and phase changes in water
  • Explore the dp/dT = l/TΔv equation and its derivation
  • Investigate the effects of density changes on freezing points at varying pressures
Students in thermodynamics, researchers studying phase transitions, and professionals in fields related to oceanography and environmental science will benefit from this discussion.
Irishpixiie
Find the freezing point of water at the bottom of the ocean where the pressure is 32.52bar
Clausius-Clapeyron equation in the form of:
Where the deltaHfusion is 6.008*10^3 J/mol
where the temperature of fusion (T1) equals 273.15
this is what I did so far:
ln(32.52bar/1.00bar)= (6.008*10^3 J/mol/8.314 J/K*mol) * ((1/t2)-(1/273.15))
The first time I solved for T2
But then I was thinking that I should have accounted for the density change but then I got stuck because I don't know how to account for this in the formula above, so should I do it before I use this formula.
If someone could just help me with the steps of this problem I know that I can get the rest of it. I have hit a wall on where to go from here.
Irishpixiie said:
1.
Where did this come from? If from pv = RT then it's not applicable since we're not dealing with an ideal gas.
Work with the basic dp/dT = l/TΔv instead. Use definite integrals!
23K
