Will this anology for zero-point energy work?
This discussion explores the analogy of zero-point energy using a basin of water and standing waves to illustrate the concept. It posits that the difference in water levels, when waves are introduced, represents a shift in mass to another dimension, suggesting that zero-point energy may arise from the vacuum converting energy into mass. The analogy emphasizes that the energy required to create mass in this context is equivalent to the mass itself, proposing a method for harvesting zero-point energy through the manipulation of waves in a water column.
  • Understanding of wave mechanics and standing waves
  • Familiarity with the concept of zero-point energy
  • Basic knowledge of dimensional analysis in physics
  • Concept of energy-mass equivalence
  • Research the principles of wave mechanics and their applications in physics
  • Study the theories surrounding zero-point energy and its implications
  • Explore dimensional analysis and its relevance in theoretical physics
  • Investigate energy-mass equivalence as described by Einstein's theory
Physicists, researchers in quantum mechanics, and anyone interested in theoretical concepts related to energy and mass conversion.
Ger
Take a large round basin of water and introduce running waves on the surface in such a manner that the combination of all waves will establish a standing wave of some sort of pattern, letters of the alfabet, appear above the original surface. The original surface level in between the apperently static figures will be a tiny bit lower as some mass has been moved into another dimension perpendicular to the surface.
Water is water, so after removal of the wave generation the surface will rise to its original value. But take the z dimension to be the dimension of mass and the x,y surface the vacuum plane. Raising the water in z direction can only be done in quanta, so that dropping back again will also only occur in quanta. If we look at the height of the crest forming the figure, it appears that this height is a slightly higher as expected if we take that level (from top to bottom) should be a measurement of the total mass. There is a little piece extra we can not get access to because if we try (by removing some of the mass) that bottom level will shift upward and we are below the surface.
Could it be that that difference we see, that level of zero-point energy is due to the fact nature took a bit of energy from the vacuum, turned it into mass?
If I would try to create a figure (next to a number of other ones) consisting out of a very thin and also very high coumn of water in which almost all the water is contained, the column itself can work as a point source for waves: the oscilators have hardly any water left to exitate and slowly water starts to leak back into the basin .
That mass is a complex combination of all kinds of running waves poping out of tiny not connected oscilators, which can only be forced back under immense pressure (decomposed into the running waves again)?
If it is true that the mass in the column is the same as the energy it took to create it, then this could be an interesting way of creating and harvesting zero-point energy from the vacuum.
  • · Replies 21 ·
  • · Replies 36 ·
10K
  • · Replies 113 ·
14K
