New Reply
bivariate normal distribution
Share Thread Thread Tools
Jun3-12, 10:19 AM   #1
Quick question on bivariate normal distribution please:
I know for a bivariate normal distribution, the two variables are marginally normal and all the conditional distributions are also normal.
Is the reverse true?
i.e. if you have two random variables that are marginally normal themselves and all the conditional distributions of one variable given a value of the other are also normal, does this result in the joint distribution has to be "bivariate normal" or it can still be another type of joint distribution?
thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jun3-12, 12:59 PM   #2
Quote by learner928 View Post
thanks.
In fact as long as they both are normal (and independent) you are done; the joined distribution will be bivariate normal.
Jun3-12, 04:01 PM   #3
Recognitions:
Quote by viraltux View Post
Independence is unnecessary.
Jun3-12, 04:59 PM   #4
Quote by mathman View Post
I didn't say it is mandatory, but if it is there then you are sure you have a jointly bivariate normal, if it is not then you have to prove it.
Jun3-12, 10:32 PM   #5
thanks guys, just to be clear,
even if they are not independent, is the joint distribution has to be bivariate normal?
no need for proof.
Jun4-12, 02:29 AM   #6
no need for proof.
Well, as I said, if X and Y are normally distributed but not independent, they might be or might be not jointly normally distributed; you need to prove it per each case.
Jun4-12, 03:35 AM   #7
on top of X and Y are normally distributed but not independent,
if all the conditional distributions are also normal, does that mean X and Y are definitely jointly normal?
Jun4-12, 04:21 AM   #8
I don't think so, the moment you are allowed to create dependencies between X and Y you can always look for a freak relationship that breaks the definition of the bivariate jointly distribution.
Jun4-12, 04:50 AM   #9
thanks,
so you don't think the fact not only all conditional distributions are normal, X and Y are also marginally normal, this is not enough to restrict the joint distribution to be bivariate normal?
Jun4-12, 07:05 AM   #10
thanks,
Nah, I don't think so. The definition of a multivariate normal distribution is not simple, one of the condition it has to follow (among other more complex than this one) is that every linear combination of its components is also normally distributed .
You could try to further constraint X and Y to behave in such a way that a particular linear combination of their values would not behave normally even if for every particular value of X and Y they do (which is basically what your restriction does). And if that does not work you could still try to mess with the other conditions.
Jun4-12, 10:17 AM   #11
thanks,
i don't have the proof, but I think the fact because X and Y are also marginally normal (on top of all conditional distributions are normal), this extra condition does make every linear combination of X and Y normally distributed hence bivariate normal, you don't think that is the case?
any idea how to proof?
Jun4-12, 10:17 AM   #12
Mathman do you know who is correct?
Jun4-12, 01:35 PM   #13
thanks,
It really looks like that, does it? Your restrictions enforce a good amount of independence between X and Y and make it difficult to find dependencies between X and Y to break the bivariate normality but, anyway, how about this one:
Imagine that given X=x the variance of the normal conditional distribution of Y is inversely proportional to x, and also imagine that the variance of X condition to Y=y is also inversely proportional to y.
Now you have X,Y, X|Y=y and Y|X=x following normal distributions, but you are getting in the bivariate distribution a contour line that looks nothing like an ellipse which is what you would expect if it would follow a bivariate joint normal distribution... yeah? I let for you the fun to do the formal proof though
Jun4-12, 03:39 PM   #14
Recognitions:
I haven't looked at the question in detail, but my instinct tells me that with all the conditions that are imposed the joint distribution should be normal.
Jun4-12, 05:56 PM   #15
With the bivariate normal PDF, the variables may be correlated. Jointly normal random variables are uncorrelated and are a special case of the bivariate normal PDF.
http://athenasc.com/Bivariate-Normal.pdf
Jun4-12, 07:47 PM   #16
I've been reading this thread for a couple of days and I also found the above referenced article. As I recall learning once, the missing condition is that the conditional variances must be constant in addition to the conditions given in the original post. I can't find any reference to this and now I'm wondering if it equivalent to the description given in this article or I'm just wrong. Any ideas?
Jun4-12, 09:24 PM   #17
viraltux, your example doesn't work as it breaks one of the restrictions.
In your case, as soon as correlation is not zero (the mean of the normal conditional distributions shift), the resultant marginal distribution is no longer normal.
In fact, the more I think about it, it does seem the only way of keeping marginal distribution of Y normal is for the normal conditional distributions of Y for each value of X follow the bivariate normal formula, with the mean shifting slightly and variance the same.
As soon as you change the variance of these conditional distributions or shift the mean in a different way, the resultant marginal distribution of Y is no longer normal.
Therefore I do still think that given the restriction of both X and Y being marginally normal and all conditional distributions being also normal, it does mean that X and Y has to be jointly normal and the joint distribution can not be anything else.
Would be great if someone can confirm this or convince otherwise.
Thanks.
New Reply
Thread Tools
Similar Threads for: bivariate normal distribution
Thread Forum Replies
Trying to generate a bivariate distribution from a univariate distribution Set Theory, Logic, Probability, Statistics 2
Finding the P(2x1>x2) for a bivariate normal distribution Calculus & Beyond Homework 3
simulating bivariate distribution? Set Theory, Logic, Probability, Statistics 2
Probability, Bivariate Normal Distribution Calculus & Beyond Homework 6
About bivariate normal Calculus & Beyond Homework 0
