What Are Parallel Universes and Their Infinite Possibilities?
  • Context: Undergrad
  • Thread starter Thread starter The Hinge
The discussion revolves around the concept of parallel universes, exploring their nature, existence, and implications. Participants raise questions about the definition of 'universe,' the relationship between choices and the existence of alternate realities, and the probability of identical Earths in an infinite universe. The scope includes theoretical interpretations, philosophical implications, and speculative scenarios.
  • Some participants propose that the vastness of space and the finite ways atoms can combine suggest the existence of identical Earths elsewhere due to probability.
  • There is confusion regarding the term 'parallel universe,' with some suggesting it could refer to different dimensions or merely distances within the same universe.
  • One viewpoint suggests that every choice made 'splits' an identical Earth into different realities, as described by the Everett Interpretation of quantum mechanics.
  • Another participant argues that the multiverse could be interpreted as the wave function distributed throughout a 3D volume of space, rather than separate parallel dimensions.
  • Some participants question whether an infinite universe guarantees the existence of identical Earths, suggesting that infinite space does not automatically imply infinite identical configurations.
  • There is a contention about the relationship between infinite space and the probability of identical Earths, with some arguing that infinite time would ensure all possibilities occur, while others maintain that infinitesimal probabilities do not guarantee multiple occurrences.
  • One participant highlights that even with infinite space, the probability of our exact Earth existing in its current state remains infinitesimal, leading to the possibility of only one such Earth.
  • Another viewpoint emphasizes that non-zero probabilities, given infinite trials, imply that events can and will happen infinitely many times, contingent on the assumption of infinite space, time, and matter.
Participants express a range of views on the existence and nature of parallel universes, with no consensus reached. Disagreements persist regarding the implications of infinite space and time on the existence of identical Earths and the interpretation of probabilities.
Participants note limitations in their arguments, including assumptions about the nature of infinity, the definitions of 'universe' and 'parallel universe,' and the implications of quantum mechanics interpretations. The discussion remains open-ended with unresolved mathematical and conceptual challenges.
The Hinge
As I understand it, there are only so many ways atoms can conbine together, and space is so vast with so many atoms in it that identical Earth's exsist else where due to probability.
Question 1. I am confused with the term 'universe'. When I say 'parrellel universe' am I talking about some other dimension, or merely a matter of distance?
Question 2. Does every choice you make 'split' an identical Earth in a parrellel universe? 'Split' meaning, the two Earth's have been identical until you decide to drive to work instead of walk. Thus on one Earth you walk to work and on the other you drive. These daliy actions relating to the possible combinations of atoms unfolding in all possible arrangments.
Question 3. If all possible combinations of atoms exsist, it is easy to assume that there exists a world where you have won the lottery or found your soul mate. However, can we also assume that there are worlds where people have evolved differently, into, say, Hobbits? And thus can we assume the The Lord of the Rings is a reality somewhere else? (I use LotR as an example, instead of the classic Matrix plug)
Question 4. If all possible combinations of atoms exist, then ANY thought that you have is really a glimps into a parrellel universe. But then I say, "But I can think up some weird stuff, like flying pigs and horses that talk." So the question becomes, are there constraints on the possible combinations of atoms? Or is absolutely anything possible?
Astronomy news on Phys.org
This first question actually states two separate theories. The Everett interpretation proposes that multiple universes exist in different realities, while other theories have all probabilities taking place in this (infinitely large) universe.
That is the Everett Interpretation in a nut shell (no offense, Mr Evrett). And as you imply, it is not limitted to just the choices we make, but the possible path of every quark, lepton, and bosson.
I think the confusion arises from science fiction, where parallel universes can mean a number of different things. If the MWI of QM is correct, I believe the multiverse literally is the wave function distributed throughout a 3D volume of space and one dimension of time. As such, alternate universes would not be located parallel to each other, but would be contained in the same volume. But I'm not sure about that interpretation, so someone will have to clarify.
You may have heard about colliding parallel universes, which is the basis of the new cyclic big bang model. In that scenario, the term universe refers to our 4D spacetime, which is a brane, a fundamental object in M theory. These branes, or universes are literally parallel to each other, but this kind of multiverse has nothing to do with the MWI of quantum theory.
Well let us speak of this universe alone.
Q: Is there enough matter and space in our universe for identical Earth's (as an example) to occurr? Assuming that the possible combinations of atoms is finite. And if 'yes' what is the difference between a massive universe containing multiple identical Earth's and a parrellel universe? (as in MWI of QM)
by the way what does MWI of QM mean exactly?
thanks.
An infinite universe has an infinite amount of matter, but there is no guarantee you'll find doubles of the Earth and people. In spite of what was written in a recent article of Scientific American, infinite space does not automatically mean an infinite amount of identical Earth's somewhere.
But if we were to assume you could have many similar Earth's by the sheer size of the universe, it is different than the MWI. In the many worlds interpretation of QM, all possible worlds exist within the same wave function. If you were to take a finite universe of a small size, you can still have an infinite number of possible states contained within that small finite volume.
I have to disagree, not on scientific grounds, but on logical ones. You see, the mathematical probability of something is directly linked to time. If there is infinite space, then there is infinite time, and thus enough "room" and enough time for the probability of all things (including many/infinite copies of Earth and the current circumstances therein) to become 100%.
I think the argument is that the probability of our exact Earth existing in its current state is infinitesimal, and so in infinite space there could still be only one. There have been some discussions about this here and on other boards. I'll see if I can dig up the posts.
An infinite volume of space does not imply an infinite duration of time.
But an infinitesimal probability is still a non-zero probability... given infinite 'trials,' any event that occurs with a probability greater than zero (however small the actual value may be) not only can happen, but will happen, infinitely many times over in fact. This is relevant to our discussion, of course, only if we assume infinite space, time, and matter. Throw any of those out the window and all bets are off.
But if there is an infinite amount of tiem, then the probability of all occurances becomes 100%, and thus there would have to be many/infinite Earths.
However, I don't see why an "infinitesimal" probability (unless that means that the probability is -[oo], in which case there couldn't even be one) should be a problem when you have infinite space. After all, no matter how much space you exhaust with non-Earth-like planets, you still have exactly as much space left to fit the Earth-like ones. Besides, if you have infinite matter, than it's supposed to go into an infinite amount of possible configurations, and many/infinite slight variations on our Earth are among those possible configurations.
Ah, I see my good buddy hypnagogue has already covered my point very well .
First, thank you all for your interest in this topic.
So, then,
If we assume that space, matter, and time are infinite...
cannot one assume that every slight variation of Earth exsist else where? And is only a matter of distance?
Furthermore, if slight variations of Earth's exsist, then drastic variations exsist as well. And thus the question becomes, is the fantastic a reality? (given infinite space,matter,&time).
So, then,
It would appear so, The Hinge. Given infinite time, space, and matter, every possible configuration of matter and energy would occur infinitely many times throughout the universe. Of course, the massive distances involved would pretty much make any explorations of 'other Earths' or 'fantastic Earths' impossible.
edit: Actually, the above might not be strictly true... we'd probably have to make some extra assumptions, like a more or less random or uniform initial distribution of mass or something of that flavor. There is also the issue of thermodynamic heat death-- if the universe kept expanding, then that would impose a limitation on possible configurations of matter and energy as a function of time. It's not even clear that an expanding universe with infinite matter is a proposition consistent with the known laws of physics. But suffice it to say that there would still be boatloads of weird, unimaginable stuff happening all over the place.
Someone mentioned the Scientific American article on parallel universes. Well, as always take everything you read with a grain of salt, but I think you'd find it very interesting and informative. The URL is http://www.sciam.com/article.cfm?articleID=000F1EDD-B48A-1E90-8EA5809EC5880000&catID=2
Here's where it gets difficult. From the Math World website: Infinitesimal is a quantity which yields 0 after the application of some limiting process.
I think we should bring this question to the math forum, or bring some of the more mathematically inclined posters over to this one.
There is no infinite time. A universe with an infinite volume still begins with a big bang.
Infinity can stretch in a single direction. An object set into motion will not come to rest unless it experiences a reaction from another mass.
IOW, time started, but it's not going to stop unless something makes it stop.
Yes the infinity makes duplication of matter(and evil uses) much more plausible. Of course I'm not a believer in infinity, so I don't buy it.
Here's something to consider. If the universe is expanding, how can it be infinite? Expansion implies a beginning and end. If the universe is expanding, it has to have a starting point, and an edge. It must exist within something else. Otherwise we have to conclude that if the universe is infinite, It's not really expanding, just moving around. And if it does have a beginning and an end, what's beyond the edge of the universe? Another form of existence. Too many incongruities. Can't except...hmmmmm
I bieleve that to continue this discussion I need from you all the definition of time.
Maybe more specificly, how are time and change different?
Expanding just means the volume of space in between galaxies increases. The universe as a whole does not get larger if it's infinite. Expansion is a local phenomena and does not describe the universe as a whole.
It implies a beginning of time, though not necessarily an end.
Nope.
  • · Replies 38 ·
  • · Replies 49 ·
  • · Replies 21 ·
  • · Replies 20 ·
