Ginsparg Applied Conformal Field Theory
The discussion revolves around the concepts presented in the first two chapters of Ginsparg's text on Applied Conformal Field Theory (CFT). Participants raise questions about the transformation properties of primary fields, the implications of compactifying spatial coordinates to eliminate infrared divergences, and the mapping of the cylinder to the complex plane for analysis using complex line integration.
  • One participant questions the invariance of the transformation of primary fields under conformal mappings, noting that the transformation leads to a different scaling behavior than expected.
  • Another participant provides a definition of invariance that aligns with the transformation laws presented, suggesting that the invariance is defined in terms of the differential forms involved.
  • Concerns are raised about the compactification of spatial coordinates and its role in eliminating infrared divergences, with some participants drawing analogies to finite systems in statistical mechanics.
  • Discussion includes the introduction of the radial ordering operator and its implications for equal-time commutation relations, with participants seeking clarification on the reasoning behind these transformations.
  • One participant expresses confusion regarding the transformation law for primary fields found in other literature, questioning how it relates to Ginsparg's formulation and whether the right-hand side of the transformation should be interpreted as a function of the transformed coordinates.
  • Another participant suggests that Ginsparg's statements may be reversed but emphasizes that the requirement for invariance is crucial for defining the transformation of scalar fields.
Participants express differing views on the invariance of transformations and the implications of compactification. There is no consensus on the interpretation of Ginsparg's statements regarding primary field transformations, indicating ongoing debate and exploration of the concepts.
Participants note that the discussion involves complex mathematical transformations and definitions that may depend on specific interpretations and assumptions, which remain unresolved.
physicus
Ginsparg "Applied Conformal Field Theory"
I have some questions concerning the first two chapters of Ginsparg's text on CFT, which can be found here
1. In equation (2.1) primary fields of conformal weight [itex](h,\overline{h})[/itex] are introduced as fields that transform the following way:
[itex]\Phi(z,\overline{z}) \to \left(\frac{\partial f}{\partial z}\right)^h \left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)^\overline{h}\Phi(f(z), \overline{f}(\overline{z}))[/itex]
Then, [itex]\Phi(z,\overline{z})dz^h d\overline{z}^\overline{h}[/itex] is supposed to be invariant. I don't understand that statement. [itex]ds^2[/itex] transforms the following way: [itex]ds^2 \to \left(\frac{\partial f}{\partial z}\right) \left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)ds^2[/itex]
Therefore, I suppose [itex]dz \to \left(\frac{\partial f}{\partial z}\right)dz, d\overline{z} \to \left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)d\overline{z}[/itex]
That leads to [itex]\Phi(z,\overline{z})dz^h d\overline{z}^\overline{h} \to \left(\frac{\partial f}{\partial z}\right)^{2h} \left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)^{2\overline{h}}\Phi(f(z), \overline{f}(\overline{z}))dz^h d\overline{z}^\overline{h}[/itex]
I don't see why this transformation behaviour should be called invariant.
2. In the section on two dimensional CFT Ginsparg compactifies the spatial coordinate in oder to eliminate infrared divergences. Is there an easy way to understand why this compactification should lead to the elimination of infrared divergences? Why does this not further constrain the generalitiy of the theory?
3. After the compactification of the spatial coordinate Ginsparg maps the resulting cylinder to the complex plane. There we can use the known tools of complex analysis to proceed, in particular complex line integration. He introduces the radial ordering operator
[itex]\begin{equation}R(A(z)B(w))=<br /> \left\{<br /> \begin{aligned}<br /> A(z)B(w) & \quad |z|>|w|\\<br /> B(w)A(z) & \quad |z|<|w|<br /> \end{aligned}<br /> \right.<br /> \end{equation}[/itex]
Then, Ginsparg claims, the equal-time commutator of a local operator [itex]A[/itex] with the spatial integral of an operator [itex]B[/itex] becomes the contour integral of the radially ordered product:
[itex]\left[\int dx B, A\right]_{e.t.} \to \oint dz \: R(B(z)A(w))[/itex]
I don't see why this is the case.
I am happy about answers to any of the three questions.
You can show that
$$\Phi(f(z), \overline{f}(\overline{z}))df^h d\overline{f}^\overline{h} = \left(\frac{\partial z}{\partial f}\right)^{h}\left(\frac{\partial \overline{z}}{\partial \overline{f}}\right)^{\overline{h}}\Phi(z, \overline{z}) \left(\frac{\partial f}{\partial z}\right)^{h} dz^h \left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)^{\overline{h}} d\overline{z}^\overline{h} = \Phi(z, \overline{z}) dz^h d\overline{z}^\overline{h}.$$
This is the usual definition of invariance.
Infrared divergences would arise from long distances in the spatial coordinate, but we cut these off by setting a finite radius. This is like putting a free particle in a finite box so that we get normalizable wavefunctions, or even just putting a gas in a finite box in stat mech. Alternatively, we could demand that our physical fields have "compact support," which roughly means that all functions are nonzero over a finite area and vanish at [itex]\pm[/itex] spatial infinity. The generality of results is not constrained if you can show that there are no divergences in observables when you take the radius to infinity (the large volume limit).
The ##\int dx \rightarrow \int d\theta## after mapping to the complex plane is explained above (2.7). The issue of radial ordering is explained in the paragraphs below (2.8), where he explains that convergence of observables is tied to time ordering. So we're really computing an "equal-time" commutation relation by slightly deforming one of the times to ##t\pm \delta t## and then letting ##\delta t## go to zero. Perhaps you can make more sense of it by mapping fig. 2 from the plane to the cylinder and seeing that the arc around ##w## corresponds to this time deformation.
Hi, thank you for your answers. They were very helpful. However, I still have some problems concerning my first question.
In other literature I often find the following transformation law for primary fields:
[itex]\Phi(z,\overline{z}) \to \Phi'(z',\overline{z}')=\left(\frac{\partial f}{\partial z}\right)^{-h}\left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)^{-\overline{h}}\Phi(z,\overline{z})[/itex]
If I use that definition I can follow your argument.
But how does that agree with
Is the right hand side [itex]\Phi'(z,\overline{z})[/itex] or [itex]\Phi'(f(z),\overline{f}(\overline{z}))[/itex]?
I would say that
$$\Phi'(f(z),\overline{f}(\overline{z})) = \left(\frac{\partial f}{\partial z}\right)^h \left(\frac{\partial \overline{f}}{\partial \overline{z}}\right)^\overline{h}\Phi(f(z), \overline{f}(\overline{z})).$$
Ginsparg states things backwards, but it should be clear that he's using the requirement that ##\Phi(z,\bar{z}) dz^h d\bar{z}^\bar{h}## be invariant in order to define how the scalar field transforms.
Ok, thanks a lot for your help!
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
