Why Do We See So Many Gamma Ray Bursts?
  • Context: Undergrad
  • Thread starter Thread starter SHISHKABOB
    Gamma Gamma ray Ray
The discussion revolves around the frequency and visibility of gamma-ray bursts (GRBs), exploring the conditions under which they are observed and the implications of their beamed nature. Participants examine the relationship between the observable universe and the rate at which GRBs are detected, as well as the assumptions underlying these observations.
  • Some participants propose that GRBs are collimated jets of material that must be directed towards Earth for detection, raising questions about their apparent frequency.
  • Others argue that GRBs are extremely bright and detectable across vast distances, with some detected at redshifts greater than z = 9, suggesting a high intrinsic rate of occurrence.
  • A participant points out that while supernovae occur at a rate of about 1 per galaxy per 100 years, only a fraction of these produce GRBs, and an even smaller fraction are aimed at Earth.
  • Another participant questions the ratio of GRBs that miss Earth compared to those that are detected, suggesting that the beaming nature of GRBs might imply a larger number of undetected bursts.
  • A later reply provides a calculation of the probability of being within the beam of a GRB, noting that the typical opening angle is about 10 degrees, which affects the likelihood of detection.
  • Some participants acknowledge that the assumption of beamed emissions is probable but not certain, indicating ongoing uncertainty in the discussion.
Participants express varying views on the implications of the beamed nature of GRBs and the calculations surrounding their visibility. There is no consensus on the exact probabilities or the assumptions regarding their emissions.
Participants mention rough estimates and calculations, indicating that there are many uncertainties involved in determining the frequency and visibility of GRBs. The discussion highlights the dependence on assumptions about the nature of GRBs and their emission characteristics.
SHISHKABOB
So, if my understanding of GRBs is correct, they are a collimated jet of material that produces a lot of gamma rays.
So my question is, don't these have to be pointing right at us for us to see them? If so, then why do we see so many? I think it's at around at least one per day, the last time I checked.
Does this mean that there are *a lot* more that we aren't seeing? Or do I have a misunderstanding of how we are able to see them?
Astronomy news on Phys.org
GRB's are so bright they are detectable throughout the observable universe. They have been detected at redshifts in excess of z = 9. Supernova, by comparison, are only detectable up to about z = 2. The beaming idea is just one possible explanation among several.
right but if they're beamed, then doesn't that mean that they have to be pointed at us for us to see them?
They do have to be aimed at us for us to see them. The answer to your question gives a feeling for just how large the universe is. Supernovae go off at the rate of about 1 per galaxy per 100 years. Since there are about 10^11 galaxies in the observable universe, that means there are about 100,000 supernovae per day in the observable universe. We think only about 1 in 1000 of these have the right conditions to produce a GRB, and only about 1 in 100 of these are aimed at us, so we see about one per day. These are very rough numbers, but you get the idea.
okay, that's what I thought. I just wanted to make sure I had the right idea about how "common" they are. I put common in quotes because I guess they're only really common when we're talking about the whole observable universe.
Also these sorts of rough guesses are good examples of why "beaming" makes sense. You can do rough numbers about how many GRB we expect to see, and they are more or less how many we do see.
shouldn't the number of bursts that miss us be a lot larger than the number that miss us? more than 1 to 100, I mean.
Unless the beams of gamma rays are very "wide", then shouldn't it be really easy for them to miss us? Or is it that the beam spreads out over long distances, similar to how lasers spread out?
I would imagine that the beam would only be as wide as a large star, since that's what forms them (according to the theory), right? So unless it spreads out as it travels, then it should be really easy to miss us, and thus the number of them that hit us should be very very very small.
This paper gives the distribution of opening angles in Figure 3. The opening angle is typically about 10 degrees. It is a fixed angle, so of course the beam spreads as you get further away. We can calculate the probability of being in the beam as follows: If the beam has an opening angle of 10 degrees (1/6 radian), this is a half-angle of 5 degrees (1/12 radian). So the solid angle of one beam is about pi*(1/12^2) steradians. Since there are two beams, and 4*pi steradians in the sphere, the probability of a given point being in the beam is about
P = (2*pi/144)/(4*pi) = 1/288
So maybe my 1/100 chance of being in the beam should have been 1/300, but I was just giving rough order of magnitude numbers, since there are many uncertainties.
This all assumes GRB's are beamed emissions, which is probable, but, by no means certain.
  • · Replies 24 ·
  • · Replies 29 ·
