| New Reply |
Strong motor using permanent magnets? |
Share Thread | Thread Tools |
| Jun7-12, 08:09 AM | #1 |
Greetings all.
I was wondering if I could build a low energy consuming but a powerful motor using neodymium magnets and a AC electromagnet(for switching poles N>S>N>S,etc...) The magnetic field created by the electromagnet could potentially attract a large and stronge neodymium magnet in the motor and repel it quickly because the magnet itself is stronger then the electromagnet, resulting in a strong, less consuming motor. Electromagnets pull/repel force rated at : 5 lb Neodymium pull/repel force rated at: 20 lb Is all of that possibile? Thanks, |
| Jun7-12, 10:56 AM | #2 |
Permanent magnet motors are "off-the shelf" items, so you are really re-inventing the wheel. Also, be aware that good motors today can be 90-95% efficient, so there really isn't much to be gained by making them more efficient.
| Jun7-12, 02:24 PM | #3 |
| Jun7-12, 07:02 PM | #4 |
Maybe I didn't understand your question. I thought you were asking whether it was possible to build an electric motor by combining permanent magnets with electromagnets which are switched to change the polarity so that they alternately attract and repel the permanent magnets. The answer is yes, it is possible. It's called a permanent magnet motor and you can buy them from many sources. Then I thought that you were asking whether the use of permanent magnets makes the motor more efficient. The answer is maybe (I think), but motors are already very efficient so there isn't much to be gained. What other questions did you have?
| Jun7-12, 08:04 PM | #5 |
| Jun8-12, 10:24 PM | #6 |
What do you all think? Are permanent magnets motors stronger and better then the conventional ones? |
| Jun9-12, 12:05 PM | #7 |
Mentor
How much better than 95% are you hoping to get?!
| Jun10-12, 10:27 AM | #8 |
Shoot, if I got over 95% I'll be going all crazy! |
| Jun10-12, 11:30 AM | #9 |
Mentor
If you can't even get 95%, how is this endeavour even worth the effort? I thought your goal was to build a more efficient motor?
| Jun10-12, 01:37 PM | #10 |
By experimenting a few things maybe I will stumble on something different and maybe in a year or two or 3,4,5 what ever reach my goal. |
| New Reply |
| Thread Tools | |
Similar Threads for: Strong motor using permanent magnets?
| Permanent magnets. | Advanced Physics Homework | 4 | ||
| Do permanent magnets... | General Physics | 1 | ||
| Re: Permanent Magnets | General Physics | 4 | ||
| Permanent Magnets | Classical Physics | 3 | ||
| Permanent Magnets | General Physics | 1 | ||
