What Are the Correct Steps to Determine the Range of a Function?
  • Thread starter Thread starter preet
    Inequalities
The discussion revolves around determining the range of functions given specific domains. The functions in question include g(x) = 2(x-3)^2 + 4 and f(x) = x^2 + 3, with domains specified for each case.
  • Participants discuss the methods used to find the range, questioning the validity of certain algebraic manipulations and the interpretation of domain limits. There is an exploration of how to identify minimum and maximum values of the functions within the specified domains.
Some participants have offered guidance on identifying the minimum and maximum values of the functions, while others express confusion about their previous calculations. Multiple interpretations of the range determination process are being explored, with no explicit consensus reached.
Participants mention the need to consider the lowest and highest values of y within the given domains, and there is uncertainty regarding the algebraic methods for determining these values. The discussion reflects a mix of anxiety about upcoming exams and a desire for clarity on the topic.
preet
What do you in these cases:
A function is g(x) = 2 (x-3) ^2 + 4
Find the range when 0 <= x <= 6
steps i took:
0 <= x <=6
0-3 <= x-3 <= 6-3
-3^2 <= (x-3)^2 <= 3^2
9 <= (x-3)^2 <= 9
22 <= 2 (x-3)^2 + 4 <=22
:: what did i do wrong?
correct answer is:
{ y | 4 <= y <= 22 }
case#2
A certain function is defined as f(x)=x^2 + 3
if -3 <= x <=3, determine the range
i got {y | 3 <= y <= 9 }
correct answer is:
{y | 3 <= y <= 12}
Thanks in advance
Preet
The range for a certain function in a certain domain will be the lowest value of y to the highest value. Let's start with case 2.
You have the lower limit right, the lowest that function will ever be (in the domain) is 3. Now the upper limit, can the function not be 3^2 + 3 = 12?
For the first case, you are not just looking at the value of y that corresponds to the upper and lower limits of the domain, you are looking for the LOWEST and the HIGHEST y values in that domain. The upper limit you got right. Now the lower limit, is there any number between 0 and 6 that you can use to make you answer lower than 22?
preet said:
0-3 <= x-3
-3^2 <= (x-3)^2
a>b does not imply [itex]a^2 > b^2[/itex], unless both are positive.
Try some examples :
2 > -3, but 4 < 9
-2 > -3, but 4 < 9
The second problem is pretty straightforward. I don't see how you could have got 9 instead of 12. Why don't you show the steps; like you did with the first problem. This will make it easier to diagnose the error.
And as for the first problem, the approach you used is not the way to solve it. Ask yourself what values of x in the domain maximize and minimize g(x).
Clearly g(x) is mimimal, for the smallest value that (x-3)^2 can take, which in turn is minimized by finding the smallest possible value that |x-3| can take. Clearly, this happens when x=3. At this value of x, what value does g(x) take ?
f(x)=x^2 + 3
domain:-3 <= x <=3
the way shown in the book is to turn the domain into the range by performing all of the operations in the function (domain -> function -> range)
-3 <= x <= 3
-3^2 <= x^2 <= 3^2
9 + 3 <= x^2 <= 9+3
12 <= x^2 <= 12
I don't even remember what I'm doing... my exam is coming up and I forgot all of this stuff... my answer doesn't even make sense. I don't know how I got the previous answer.
Is there some algebraic method of doing this or do you have to think every time which value will give you the min/max values? Even looking at the first one, shouldn't the range be 3 <= y <= 22? 3 is between 6 and 0 and gives the lower y value... but the answer in the book says 4. If you want to apply the method where you apply all of the operations of the function, do you have to find like the greatest and least absolute value or something? TiA.
preet said:
f(x)=x^2 + 3
domain:-3 <= x <=3
-3 <= x <= 3
-3^2 <= x^2 <= 3^2
9 + 3 <= x^2 <= 9+3
12 <= x^2 <= 12
Please read my post. I've told you why you can't do this.
Yes, y= g(x) = 4, when x=3. Please read my posts slowly and carefully. You're panicking, and that just doesn't help you one bit. Calm down and start over.
  • · Replies 38 ·
