Classification of stars by spectrum
The classification of stars is primarily based on their temperature, with the Hertzsprung-Russell diagram being a key tool for visualizing this relationship. O class stars share similar spectra and absorption lines, indicating their high temperatures and mass. As stars evolve, they transition through stages of burning hydrogen, helium, and heavier elements, which alters their spectra and brightness. The Main Sequence is defined by the correlation between a star's temperature and brightness, with most stars falling along this line.
  • Understanding of stellar evolution stages
  • Familiarity with the Hertzsprung-Russell diagram
  • Knowledge of absorption lines and their significance
  • Basic grasp of the Stefan-Boltzmann law
  • Research the Hertzsprung-Russell diagram in detail
  • Study the process of stellar evolution and nuclear fusion
  • Explore the significance of absorption lines in spectroscopy
  • Learn about the different classes of stars and their characteristics
Astronomers, astrophysics students, and anyone interested in understanding stellar classification and the properties of stars.
ehabmozart
This topic is quite confusing.. In the first place, how can we classify for example all O class stars would be having the same spectrum with the same absorption lines... Secondly, i just need a clarification on what do these absorption line reprsent and upon that how can we decide whether a star is in it main sequence or not.. Whoever dominates, i am thankful to him!
Astronomy news on Phys.org
The basic thought behind stellar classifications is that all stars start out as hydrogen, and that the major difference between types is the mass of the star. As a star ages, it advances in stages through burning hydrogen, helium, carbon, and heavier elements. As this happens, the spectrum of the star changes, and it becomes brighter, advancing up the Main Sequence.
The absorption lines represent chemical elements in the star's atmosphere. You can also tell a star's temperature by looking at the overall spectrum curve and applying the Stefan-Boltzmann law. When you do that, it's clear that generally the brightest stars are also the hottest. If you plot a large number of stars on a chart with brightness on one axis and temperature on the other, most stars will fall on a line called the Main Sequence. A chart like that is called a Hertzprung-Russell diagram.
The classification of stars is by temperature (which you can always determine) rather than brightness (which can be tricky). So for example, all G1 stars are the same temperature (actually, same temperature range), regardless of their brightness or whether they're on the Main Sequence or not.
