We can't know the velocity and position of a particle accurately ?
The discussion revolves around the feasibility of an experimental setup to measure both the position and velocity of a particle, specifically an electron, using photons. Participants explore the implications of their proposed methods in light of quantum mechanics, particularly Heisenberg's uncertainty principle.
  • Exploratory, Technical explanation, Debate/contested
  • One participant proposes an experiment where two photons are sent towards an electron to measure its position and velocity, suggesting that the photons could cancel each other's energy effects.
  • Another participant questions the assumptions made in the thought experiment, highlighting the need to consider the implications of those assumptions.
  • A revised proposal is made, suggesting that the timing of the photon impacts could allow for the calculation of the electron's new position and velocity, likening it to measuring blood flow velocity.
  • Concerns are raised about the applicability of Heisenberg's uncertainty principle to the proposed experiment, particularly regarding the measurement of energy and time.
  • A participant expresses confusion about whether the exact energy of the particles used in experiments can be known, indicating a lack of clarity on the implications of uncertainty in experimental physics.
Participants do not reach a consensus on the feasibility of the proposed experiment or the implications of Heisenberg's uncertainty principle. Multiple competing views and interpretations remain present throughout the discussion.
Participants acknowledge the limitations of their assumptions regarding the behavior of photons and particles in the proposed experimental setup, as well as the implications of quantum mechanics on their measurements.
The_Thinker
i was wondering, if we can arrange this kind of experiment... What we do is this, we send photons (or whatever u choose) directly opposite to each other of which the energy is exactly the same such that if there is nothing is in their path the would anihialate each other.
Now, if something was in their path although... the following would happen...
We have two photons let's name them 1 and 2. Now, we know where the atom is so we position both the phtons equidistant from each other. Photon 1 and 2 hits the electron at the same time and therefore there is no change in the position of the particle.
Even if there is as in if 1 hits first and then 2 although we might have displaced it we know its present position now thanks to diffrence in wavelength of the photons.
And with another pair we can set it back to its original place. So in essence there should be no change in their position and we should be able to calculate the velocity in the same way, right...?
"we know where the atom is"
"we position both the phtons equidistant from each other"
"Photon 1 and 2 hits the electron at the same time"
Think about all these assumptions in your thought experiment:)
good point :)
but how abt this, i changed it...
We have two photons let's name them 1 and 2. Now, we send these little critters oppsoing to each other. Photon 1 and 2 hits the electron one at one time and the other a few milli or whatever seconds later. Now whatever extra energy is brought abt by 1, it will be canceled by 2 and now we know the new position which we can calculate by knowing the diffrence in wavelength between 1 and 2 and we can also calculate it's velocity at the same time, kind of like the way we calculate the velocity of bloodflow...
And with another pair of our guys we can set the particle back to its original place. So in essence there should be no change in their position and we should be able to calculate the velocity in the same way, right...?
Yer still doing it ;)
Remember that Heisenberg's uncertainty applies to time and energy as well.
i always thought that we knew the exact energy of the particles we willingly send out for experimentation.
So do i take it that u are telling me that we don't know the exact energy of the particles of that we send out?...
oh well it was worth a shot...
thx... :)
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 41 ·
  • · Replies 64 ·
  • · Replies 20 ·
