| New Reply |
Circuits with Series and Parallel Wiring |
Share Thread | Thread Tools |
| Jun8-12, 07:25 PM | #1 |
I attached the problem. I'm pretty confused. I remember the equations for parallel and series circuits, but I have no idea how to do this. I attempted, but failed. I know the two 10 ohm resistors are in parallel (so Rnet is 5), and the 20 ohm and the 6 ohm resistor are in series (So Rnet is 26). But then are those in parallel or series? And then i just don't know how to do the problem.
| Jun8-12, 07:44 PM | #2 |
The 10-ohm resistors are in parallel, but the 20-ohm and 6-ohm resistor aren't in series.
| Jun8-12, 07:47 PM | #3 |
| Jun8-12, 08:12 PM | #4 |
The 20-ohm and 6-ohm are not in series because there's something else connected to the node where the two resistors are connected. If two elements are in series, all of the current in one element has to go through the other element. For example, the battery and the 6-ohm resistor are in series. You should be able to see that all of the current that flows through the battery has to also go through the 6-ohm resistor. That's not the case with the 6-ohm and 20-ohm resistor. Some of the current that goes through the 6-ohm resistor will branch off to go through the 10-ohm resistors.
| Jun8-12, 08:17 PM | #5 |
| Jun8-12, 08:21 PM | #6 |
10 ohm resistors aren't in a series and are parallel but the other two are in a series. I find it easy to see if they are parallel or series by redrawing the diagram to one you are comfortable with. At every split in the wire with resistors, just branch it off.
| Jun8-12, 08:27 PM | #7 |
| Jun9-12, 06:16 AM | #8 |
Mrcheeses is wrong. The two resistors are not in series.
See http://www.facstaff.bucknell.edu/mas...t/Resist2.html |
| Jun9-12, 06:53 AM | #9 |
Recognitions:
I redraw the circuit making the wires a bit shorter and moving the ammeter closer to the resistors, but the circuit is equivalent with the original one. Note that the ammeter can be replaced by a single piece of wire. Which resistors are connected in parallel?
ehild |
| Jun9-12, 06:55 AM | #10 |
Yes, 10,10 and 20 ohms are in parallel.
| Jun9-12, 12:41 PM | #11 |
| Jun9-12, 02:13 PM | #12 |
Recognitions:
Yes, the resultant of the parallel resistor is 4 ohm. And the resultant is connected to the 6 ohm resistor, and the whole is connected to the battery. You can use V=RI to get the total current.
What current does the ammeter read? |
| Jun9-12, 03:15 PM | #13 |
So... 20=10I I=2 A But 2 is wrong, so I don't know. |
| Jun9-12, 03:29 PM | #14 |
Recognitions:
The ammeter does not read the current flowing through the battery. It reads the current that flows through itself. It is connected in series with what ?
ehild |
| Jun9-12, 03:46 PM | #15 |
| Jun9-12, 03:59 PM | #16 |
Recognitions:
And you can find the voltage. ehild |
| Jun9-12, 06:01 PM | #17 |
| New Reply |
| Tags |
| circuits, current, parallel, power, series |
| Thread Tools | |
Similar Threads for: Circuits with Series and Parallel Wiring
| Series parallel switch wiring | Electrical Engineering | 0 | ||
| Circuits with series and parallel wiring | Introductory Physics Homework | 1 | ||
| Circuits with Series/Parallel Wiring | Introductory Physics Homework | 3 | ||
| Parallel and Series Circuits | Introductory Physics Homework | 2 | ||
| correct series-or-parallel-or-off switch wiring? | Electrical Engineering | 6 | ||
