Bell's test: Introducing a control experiment
The discussion revolves around the concept of Bell's test and the introduction of control experiments involving unentangled photons. Participants explore the implications of using unentangled photons with same and random polarizations in comparison to entangled photons, focusing on the probabilities associated with different polarizer orientations.
  • Some participants propose introducing unentangled photons with the same polarization as a control experiment and question the expected probability relations between different polarizer angles.
  • Others clarify that for unentangled photons, perfect correlation at identical angles does not hold, which is a crucial assumption for deriving Bell's inequality.
  • A participant mentions that the probabilities can be calculated using the formula cos²(θ1-θ2), where θ1 is the angle of the unentangled photon and θ2 is the angle of the polarizer.
  • There is a discussion about the significance of Bell's inequality, with some asserting that quantum mechanics predicts a stronger correlation than classical probability allows.
  • One participant provides a quick calculation of probabilities for specific angles, suggesting P(-30,30) = 37.5% and P(-30,0) = P(0,30) = 25%, but acknowledges a previous mistake in their calculations.
Participants express differing views on the implications of using unentangled photons in the context of Bell's inequality, and there is no consensus on the expected outcomes of the control experiments. The discussion remains unresolved regarding the exact nature of the correlations and probabilities involved.
Limitations include the dependence on the assumptions made about the nature of the photons and the specific angles used in calculations. The discussion also highlights the complexity of applying Bell's inequality to unentangled photons.
San K
If we were to introduced a set of un-entangled, but same polarized, photons as control experiment what would the results be of the control experiment?
So we have the following three cases:
Bell test Experiment: Send entangled photons
Result is that P(-30,30) is not equal to P(0,30) + P (0,-30)...hence QE proved...
(side note - with not all loopholes closed simultaneously)
Control Experiment 1: Send "un-entangled" photons, but same polarization
What would the relation be between P (-30, 30), P(0,30) and P(0,-30)?
Control Experiment 2: Send "un-entangled" photons, but random polarization
I guess in the last case it would be 0.5, 0.5, 0.5
I assume by P(x,y) you mean the probability of mismatch between the results of a polarizer oriented at an angle x and a polarizer oriented at an angle y. And one correction, it's called Bell's INequality, not Bell's equation for a reason. Bell's inequality in this case, is P(-30,30)≤P(-30,0)+P(0,30), so the significant fact is that QM predicts P(-30,30) is greater than P(-30,0)+P(0,30). The significant fact is not merely that P(-30,30) is not equal to P(0,30)+P (0,-30).
Well, the photons aren't entangled, then you no longer get perfect correlation at identical angles, i.e. it is no longer true that P(x,x)=0 for all angles x. But this is a crucial assumption for deriving the Bell inequality, so the Bell inequality need not apply in this case.
Still, if you want to calculate the probabilities anyway it's pretty straightforward (though tedious) to compute. All you have to know is that given an unentangled photon polarized in a direction θ1, the probability that it will go through a polarizer oriented at an angle θ2 is cos2(θ1-θ2).
Yes, you're right about that.
Thanks Lugita.
agreed.
a better answer is that - the correlation is stronger than that predicted by the laws of probability...
Same polarized photons won't give same answer for polarizers that are aligned? (i.e. polarizers are same angles to each other)
However entangled photons will give the same answer for polarizers that are aligned?Bell's inequality does not apply. We are simply comparing polarized non-entangled photons with entangled photons (which necessarily are non-polarized). there is a reason for this.
lugita15 said:
Still, if you want to calculate the probabilities anyway it's pretty straightforward (though tedious) to compute. All you have to know is that given an unentangled photon polarized in a direction θ1, the probability that it will go through a polarizer oriented at an angle θ2 is cos2(θ1-θ2). Yes, you're right about that.
ok, just wanted to get the probabilities for P(-30,30), P(-30,0) and P(0,30), assuming Theta 1 is Zero degrees.
San K said:
a better answer is that - the correlation is stronger than that predicted by the laws of probability...:)
It's the laws of probability plus local hidden variables.
OK, based on a quick calculation in my head, P(-30,30)=37.5%, and P(-30,0)=P(0,30)=25%. EDIT:Sorry, I made a mistake the first time. Now the numbers should be right.
  • · Replies 58 ·
  • · Replies 61 ·
