Simple reflection thought experiment
The discussion revolves around a thought experiment involving a particle and its interaction with a wall, specifically addressing whether the particle comes to a complete stop upon reflection and how this relates to the behavior of light when it reflects off a mirror. The scope includes conceptual reasoning and comparisons between classical mechanics and quantum mechanics.
  • Matt Tucker proposes that a particle must come to a complete stop before it can change direction upon hitting a wall.
  • Patrick suggests an alternative view where the particle disappears and a new one appears with opposite velocity at the moment of impact.
  • Marlon argues that the phenomena of a bouncing ball and a reflecting photon are fundamentally different, requiring different descriptions: classical mechanics for the ball and quantum mechanics for the photon.
  • Marlon further explains that the incident photon is not the same as the reflected photon, indicating a process of absorption and emission at the wall.
  • Another participant notes that at the moment of impact, the ball's kinetic energy is converted into potential energy due to elastic deformation, while light is absorbed and re-emitted by the wall's atoms.
Participants express differing views on whether the particle comes to a complete stop and how this relates to the behavior of light. There is no consensus on these points, and the discussion remains unresolved.
The discussion highlights the limitations of applying classical mechanics to quantum phenomena, as well as the assumptions regarding the nature of particles and light in reflection scenarios.
MattTuc13
I am going to start out with a simple thought experiment:
A particle is moving towards a wall at a 90 degree angle. The wall is perfectly smooth; therefore, when the particle bounces off, it will be traveling along the same path as it did when it came in.
Does the ball ever come to a complete stop? To me, it makes since that it would have to completely stop before it can turn around and come back.
If you say yes:
What about light... if light reflects off of a mirror at a 90 degree angle, then it can't stop, so how does it change directions?
If you say no:
Please explain how the particle does not stop at the instant it hits the wall.
Thanks for your help!
-Matt Tucker
-Matt Tucker
Sorry! I just realized that the ball here should be listed as particle.
I would think that somebody would have an answer to this question...
MattTuc13 said:
If you say no:
It disappears, and at that very moment, a new one appears with opposite velocity ? For instance ?
cheers,
Patrick.
Problem is you are looking at two phenomena that maybe look alike but that are fundamentally different in nature. The instant change in impulse will be valid for the ball by applying classical mechanics. However for the photon, a QM-description is required. In this case you cannot look at the photon as a billiard ball. The incident photon is NOT the same as the reflected photon and the answer of vanesch illustrates that. It is indeed what happens: absorption and emission of the photons at the wall...
regards
marlon
At one point in time the ball indeed stops. It's initial kinetic energy is now in the form of potential energy by the elastic deformation of the ball and wall. When light hits a wall it is absorbed, and it excites the atoms making up the wall. The excited atoms 'fall' down from their excited states to their ground state while re-emiting the energy in the form of radiation. So the light does not stop, but is absorbed and re-emitted.
Thank you very much, that makes much more since!
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 36 ·
10K
