Which Type of Semiconductor Has Higher Resistance: N-Type or P-Type?
The discussion centers on the comparative resistance of N-type and P-type semiconductors, specifically in the context of silicon. Participants explore the implications of doping on conductivity and resistance, considering both theoretical and conceptual aspects.
  • Some participants assert that N-type semiconductors have an excess of free electrons due to doping with pentavalent atoms, which they believe may lead to higher resistance due to the presence of bound electrons from the dopant.
  • Others argue that P-type semiconductors, which create holes through doping with trivalent atoms, may be more conductive because electrons can more easily fill these holes, potentially leading to lower resistance.
  • A participant suggests that the presence of bound electrons in N-type materials could impede electron flow from a power source, while the open holes in P-type materials might facilitate better conduction.
  • Another viewpoint emphasizes that doping, whether N-type or P-type, generally increases conductivity and reduces resistance, challenging the notion that one type is inherently more resistant than the other.
  • One participant uses an analogy involving video game mechanics to illustrate their understanding of electron transport, suggesting that the dynamics of electron movement in semiconductors may not align with their analogy.
Participants express differing views on whether N-type or P-type semiconductors exhibit higher resistance. There is no consensus on which type is more resistant, as arguments for both sides are presented without resolution.
Participants' claims depend on various assumptions about electron behavior and the effects of doping, which are not fully resolved in the discussion. The complexity of semiconductor physics and the interactions between charge carriers are acknowledged but not conclusively addressed.
Windex
In terms of the semiconductor Silicon:
N types have on more free electron added to its structure from doping an impurity on it. Such as an arsenic impurity onto a pure intrinsic silicon crystalline structure.
However wouldn't it having one more electron inside of it that is bound to the arsenic atom make the ntype more resistant to electron flow from a power source with an emf/voltage/potential difference?
I also wonder about the vice versa for the P-type.
Wouldn't the P-Type be more conductive unlike the N-Type which i am assuming to be resistive?
Mainly because when doping something onto a silicon structure to make it a N-Type a hole is created. Thus allowing electrons to want to take that hole for transportational use.
Windex,
Adding impurities to metals (which already have loads of conduction electrons) increases their resistivity a little. The impurities just get in the way.
But the thing about silicon is that without the impurities, there are hardly any conduction electrons, at least at room temp and below. So adding even tiny amounts of a dopant impurity (either an n-type or p-type) reduces the resistivity by orders of magnitude.
When you dope silicon with penta-valent atoms, (i.e. n-type semicondoctor) then there will be an excess of electrons. When connect it to a power source, which can be viewed as an electron drain if you're looking from the positive charge, then this will tend to suck the free electrons from the semiconductor, and of course, the negative end which can be viewed as an electron sourse, will supply the semiconductor with the electrons needed for continuous 'sucking'.
For p-type, tetra-valent doping will creat a hole, which can be simply viewed as a positive charge. So when you connect it to a power supply, then electrons supplied from the negative end, will fall in the hole, and the pushed to the other end by the stream of electrons to be re-collected at the positive end of the source.
Hope i was clear :rolleyes:
ehh.
I was more going on the point that there is an open hole instead of an electron floating around in the p-type. Since ther is a whole, electrons would more likely be able to conduct better. However in the n-type, there is a bound electron put there by the impurity. Thus electrons that are being brought from a power source have to fight that electron. :approve:
Or else I'm being stupid.
I thought electrons liked to use other electrons holes as a pathway to getting somewhere faster.
Kinda like in sonic the hedgehog where you go through a speed door and you get a super speed boost to get done with the level faster. You could use the n-type which is not take the speedwarp door and fight through the badguys which is the bound electron put there by the impurity, or else you could take the p-type which would have less resistance and a speed door that gives you a boost and less badguys to fight. :-p
eh.
So basically. There is resistance added because of the impurity. But my question was. Which would be more resistant: N-type or P-type?
eh.
Having more electrons in the conduction band (which is what adding an N-type impurity does) or more holes in the valence band (from P-type dopants) only increases the conductivity. Your understanding of electron transport is a little off. The model that explains semiconductors well assumes that there is virtually no interaction between the electrons themselves, and it turns out that this is a good assumption to make. As a result, the conductivity is linearly proportional to the number of free charge carriers (per unit volume).
So in fact doping increases conductivity and reduces resistance, irrespective of whether it's N- or P-type.
Moral : Electron transport does not work like Sonic.
13K
  • · Replies 0 ·
17K
