New Reply
How to show that light travels through space, but not time
Share Thread
Jun9-12, 11:15 PM   #1
Use relativistic equations and γ to demonstrate the following:
b) Light travels through space but not in time
2. Relevant equations
Lorentz factor γ = 1 / √(1 - [v/c]^2)
Time dilation t = γ t°
Length contraction L = γ L°
Mass relativity m = γ m°
E = m c^2
3. The attempt at a solution
To be honest, I'm not exactly sure how to approach this. I don't quite understand the concept behind what the question is really asking for. Furthermore, I don't know how I can use these equations to prove that light does not travel through time.
PhysOrg.com science news on PhysOrg.com
>> A robot that runs like a cat (w/ Video)
>> Global cooling as significant as global warming, research shows
>> 'Chase and run' cell movement mechanism explains process of metastasis
Jun10-12, 12:04 AM   #2
Consider a particle traveling at a uniform velocity relative to the observer. Compare a fixed time interval t0, perhaps 1 second, in that particle's reference frame to the corresponding time interval in the observer's reference frame. Ie., pretend the particle is carrying a clock that ticks once every second.
How long does the observer have to wait to observe one tick if the particle travels at 0.9c ? At 0.95c? At 0.99c? 0.999c?
Does this behavior continue if we make the fixed unit of time for a single tick smaller? What does this imply about theoretical particles carrying these same clocks that travel at c?
With the formulas you have, you can only make a weak implication.
Jun10-12, 01:37 AM   #3
Quote by slider142 View Post
Consider....
Thank you. I can't quite wrap my head around this, but I think I have a good enough idea to somehow explain this. I'll be sure to ask my teacher when I can.
New Reply
Tags
light, relativity, space, special, time
Similar Threads for: How to show that light travels through space, but not time
Thread Forum Replies
Assume light travels from point a to b. Find the total time to get from a to b Calculus & Beyond Homework 17
Which travels more slowly in glass, red light or violet light? Introductory Physics Homework 4
Light has mass, and it travels at the Speed of light, so a massless object..... Special & General Relativity 2
Future,time,space and light Astrophysics 1
