| New Reply |
2 slit experiment again |
Share Thread |
| Jun10-12, 03:07 AM | #1 |
2 slit, double slit, two slit
I saw a previous topic where someone asked if anyone has tried the 2 slit experiment with bigger objects (not Bucky balls) like sand or golf balls, but it seems not? I wondered if the diffraction patterns could simply be a result of the particles deflecting off the edges of the slits? Also what is the nature of the source of the particles, is it a single point source of light or electrons that 'sprays' across the area of the 2 slits? And how are the slits cut in the material? With sharp flat edges or angled? Maybe double slits in a single layer gold leaf film would be good to try? Perhaps gravity could be the force to propel sand or some other macro particles through slits: just pour it down in a stream. I guess the size/velocity ratio might disallow the necessary deflections required to make a pattern though? |
| Jun10-12, 03:35 AM | #2 |
| Jun10-12, 03:49 AM | #3 |
Staggered in space/time, doesn't that imply it's not an interference pattern they're seeing?
It seems like stretching an elaborate theory around a false assumption. Pity someone doesn't try the experiment with a table tennis ball shooting machine, they might see similar patterns due to balls glancing off the edges of the slits. |
| Jun10-12, 04:26 AM | #4 |
Hi swhite44.
No that wouldn't work, the double slit experiment showing a diffraction pattern is all about a particle 'interfering with itself' 'as long as it can't be determined which slit it went through' A heavy object being deflected by a sharp edge would certainly be identified as going through one or the other slit and therefore the diffraction pattern wouldn't appear, just as it disappears for a tiny particle which you observe too closely |
| Jun10-12, 04:55 AM | #5 |
Yes I know the interpretation of the results of the experiment is that the pattern is a diffraction pattern caused by quanta somehow interfering with themselves, but maybe the pattern has some more rational cause?
| Jun10-12, 05:01 AM | #6 |
This 'somehow interfering with themselves' is mind boggling
In order to try to understand how this can possibly happen, it has been tried to 'look at what happens' (does the particle goes through this slit, or the other one ? or both ?) Every time this is done, there is no longer any diffraction, you are back to the same effect you would expect with tennis balls or whatever 'macro-particle' This is the key point and the answer about 'has it been tried with bigger objects' ? yes it has, in fact it has been tried a lot 'not to do so' :) |
| Jun10-12, 08:07 AM | #7 |
So whatever they do to detect which slot the photon goes through, removes the wave property?
Can't they fire charged particles through some gas so they leave a trail? Better to use a less invasive detection method. |
| Jun10-12, 08:26 AM | #8 |
No, as you said *whichever* method being used
it goes beyond the fact that someone looks at it, the same thing applies to the involved system regardless of the experiment. As soon as something is recorded, it is over. So, if the particle bounces over one slit wall with enough force that it had any impact on said wall (increased momentum/temperature/whatever that makes it a measurably different wall after than before) then it is determined that the particle went through this one slit, and no interference will show, simply because there is no interference any more: the particle went through this, or this slit and that is the end of it. On the other hand, if there is no way to tell, not because our measurement apparatus isn't sensitive enough, but because there is physically no way to tell at all, then, and only then, will the interference pattern appear. |
| Jun10-12, 10:55 AM | #9 |
Doesn't make sense, unless the method of measuring or recording which slit the particle goes through changes the properties of the particle.
Maybe the photon is embarrassed to be a just a mere formless wave, so it pretends to be solid matter if someone is watching? |
| Jun10-12, 11:00 AM | #10 |
Indeed, the measuring changes the properties of the particle, this is Heisenberg's uncertainty principle, except it goes far beyond 'someone watching' and goes straight through the actual individual existence of said properties.
| Jun10-12, 11:23 AM | #11 |
That's pretty poor, can't they improve their measuring technique?
It's like measuring the speed of Nadal's serve in the French open today and saying 'that serve was 90 miles an hour, but the radar knocked the ball out of court so it's not counted'. |
| Jun10-12, 11:30 AM | #12 |
There is no 'they' :)
This has nothing to do with measurement technique and everything to do with how things behave at the fundamental level, that is, as far as I know, the universe itself doesn't know what was the exact parameters of said service. |
| Jun10-12, 11:32 AM | #13 |
or may its like saying i dont understand what your saying so you must be wrong and i cant believe how poor your answer was. or maybe its just like being a troll?
| Jun10-12, 11:33 AM | #14 |
of course you could just do the maths?
| Jun10-12, 11:37 AM | #15 |
You lost me there.
If measuring which slit a particle passes through removes the wave quality of the particle, then there's something intrusive about the measuring technique isn't there? So 'they' who do the measuring should devise a more sneaky subtle technique. It's as if the particle knows it was tracked? |
| Jun10-12, 11:42 AM | #16 |
hey, this is a fanciful question. this experiment, if actually carried out at all, wouldn't give any "measurable" and satisfactory result. the diffraction effects would be so small (you can calculate it using de Broglie hypothesis) that it cannot be measured. furthermore, the two-"slit" experiment requires that you have an horizontal continuous array of tennis ball shooter as ball-quanta sprayer. and then there is gravity... with all this, I don't think it's worthwhile to do this now. perhaps the next century will have the proper technology to do that.
| Jun10-12, 11:49 AM | #17 |
The particle does not have a wave behaviour any more than it has a 'regular particle' behaviour
It's a particle, and it behaves differently than a tennis ball Measurement changes the outcome of the experiment, but the experiment carries on without anyone watching anyway, that is, in order for the particle to take a definite path (through one slit or the other) it would 'leave a mark' regardless of someone putting an apparatus to check this mark. If the particle interacts with any slit in anyway that is *physically* meaningful, then the particle went through that slit, and that is is, no confusion, no interference. If on the other hand whichever path the particle took is absolutely untraceable, as in, 'not even the universe itself as any way to tell', then you can conclude, in a way, that it went through both slits, and the interference shows. Of course it is more complicated than that, one particle does not, in fact, interferes with itself, but if the conditions of experiment are right, then, over time, one particle after the other, the interference pattern will show. the interference happens lower, at the probability level. |
| New Reply |
| Tags |
| 2 slits, double slit, two slits |
Similar discussions for: 2 slit experiment again
| Young's Double Slit Experiment - Slit Separation Calculation | Introductory Physics Homework | 2 | ||
| Young's double slit experiment (shallow slit and deep slit) | General Physics | 4 | ||
| Dual slit experiment: closing/opening a slit after the particle passes it . . . | Quantum Physics | 1 | ||
| double-slit experiment when screen distance is of same magnitude of slit separation | General Physics | 4 | ||
| Problem: Plastic Covering One Slit in Double Slit Experiment | Introductory Physics Homework | 5 | ||
