How do particle scattering cross sections scale with energy in colliders?
The discussion revolves around how particle scattering cross sections scale with energy in colliders, specifically focusing on photons, electrons, protons, and heavy nuclei like gold and lead. Participants explore theoretical implications, empirical data, and the behavior of different particles in high-energy collisions.
  • One participant suggests that the total scattering cross section for photons may vary as the inverse square of the energy, citing the Heisenberg uncertainty principle and the energy-wavelength relationship.
  • Another participant argues that general relativity implies that the cross section of heavy nuclei, such as gold or lead, remains constant with increasing energy due to dimensional effects.
  • There is a discussion about the behavior of electron cross sections, with one participant noting a falling power law in the background of resonant particle data.
  • One participant references the Froissart bound, indicating that the total cross section for protons rises slowly, potentially explained by the pomeron, while also noting the complexity of elastic proton-proton scattering.
  • Another participant raises a question about why electrons, considered point particles, exhibit a falling cross section while protons, composed of quarks, show a rising cross section.
  • It is mentioned that protons do not have a fixed number of partons, and as energy increases, more partons contribute to the inelastic cross section, leading to a weak energy dependence.
  • Heavy ions are compared to protons, with the disk approximation being more applicable due to their larger size.
Participants express differing views on the scaling of cross sections for different particles, with no consensus reached on the specific relationships or underlying reasons for the observed behaviors.
The discussion highlights the complexity of particle interactions and the various theoretical frameworks that may explain the observed phenomena, including the need for empirical data to support claims. Limitations in assumptions and definitions are acknowledged but not resolved.
This discussion may be of interest to those studying particle physics, collider experiments, or the theoretical underpinnings of scattering processes in high-energy physics.
jimgraber
Particularly photons, electrons, protons, and gold or lead nucleii?
(If necessary, break this into four separate questions.)
It is stated that due to the Heisenberg uncertainty principle, it takes more energy to measure a smaller distance and the inverse wavelength energy-wavelength relationship for photons is well known.
Therefore, I would conclude that the (total scattering) cross section for photons at least would vary as the inverse square of the energy.
On the other hand, general relativity says the the longitudinal dimension shrinks with increasing velocity, but the transverse dimensions do not.
Therefore, I would conclude that the cross section of say a gold atom in RHIC or a lead atom in the LHC would basically remain constant as the energy increased.
But how about the electron, supposedly a point particle?
Due to PEP and LEP, we should have good data on this.
Looking at PDG figure 41.6,
<http://pdg.lbl.gov/2011/reviews/rpp2011-rev-cross-section-plots.pdf>
I see lots of big spikes for resonant particles, but the underlying bacground is clearly a falling powerlaw that I think looks like it could be an inverse square law.
The proton cross sections in the next few figures, e.g. 41.7 and 41.11, show a falling elastic scattering cross section, but they also show an approximately constant total cross section.
What little I've found for RHIC supports the approximately constant cross section.
Therefore I conclude that the cross sections of photons and electrons (neglecting resonances) scale as the inverse square of the energy, but the cross sections of protons and nucleii are roughly constant with energy.
Comments or corrections?
So is it true that the photons and electrons are different from the protons and nucleii?
And why don't the protons scatter as three or six point particles (quarks and gluons) instead of one big blob?
According to Fig 41.6, the ratio between total e+e- scattering and e+e- → μ+μ- scattering is roughly constant, and the latter is 4π α2/3s. Where s of course is the Mandelstam variable s, equal to the square of the center of mass energy.
From the other Figs, total pp cross section rises slowly, like ln2(s). This is explained elsewhere as due to the pomeron.
http://www.phy.bnl.gov/pp2pp/information/presentations/1999/Asilomar-99.pdf shows how complex the elastic pp cross-section is. In the high energy region it is said to fall like s-10.
At high energy a pp collision is really a single parton-parton collision, with the other partons acting as spectators.
So why does one point particle (the electron) have a falling cross section, and three point particles (the quarks in a proton) have a rising cross section?
TIA for any reasonable explanation.
σ ~ ln2(s) is known as the Froissart bound, and Froissart's theorem limits σ to this growth rate or less, relying only on basic assumptions such as locality and unitarity.
Pomeron theory predates QCD, and was developed as a largely empirical explanation of the observed rising tendency in the total cross section. A pomeron is a Regge trajectory, an infinite family of particles with increasing spin, and exchange of these things is what produces the rise. The challenge is to derive this idea from something more fundamental.
The subject is complex, and I can only point you to references such as this one, which derive the behavior from perturbative QCD.
Protons do not have a fixed set of partons. If you go to smaller energy fractions x, the number of partons per energy grows beyond limit. Therefore, if you increase the beam energy, more and more partons can contribute to the inelastic cross-section. The result is that high-energic protons are similar to disks - if they collide, some partons inside will interact. This gives a cross-section with a weak energy-dependence.
Heavy ions are similar to protons. The disk approximation is even better there, as they are larger.
