Why do morphisms in category of rings respect identity
  • Context: Graduate
  • Thread starter Thread starter algebrat
    Identity Rings
The discussion revolves around the properties of morphisms in the category of rings, specifically focusing on why these morphisms must preserve the identity element. Participants explore the implications of category theory axioms on ring homomorphisms and the distinction between unital and non-unital rings.
  • Some participants seek intuition regarding the necessity for morphisms in the category of rings to preserve the identity element, questioning whether this is a requirement of the definition or a stronger condition.
  • One participant suggests that if the category requires multiplicative identities, morphisms must respect that to remain within the category, while noting that in categories without identity, such as pseudo-rings, this restriction does not apply.
  • Another participant clarifies that general ring homomorphisms do not necessarily need to preserve the identity unless explicitly defined as unital ring homomorphisms, providing the example of the zero function as a morphism that fails this condition.
  • Further discussion highlights that the inclusion of the axiom f(1)=1 is necessary because it is not implied by the other axioms of ring homomorphisms, indicating a distinction between full and non-full subcategories in categorical terms.
  • Participants agree that the additional rule for unital ring homomorphisms is essential due to the presence of extra structure that is not automatically preserved.
Participants express varying interpretations of the original question and the implications of morphism definitions, indicating that there is no consensus on the necessity of the identity preservation in all cases. The discussion remains unresolved regarding the nature of morphisms in different contexts.
The discussion touches on the limitations of definitions in category theory and the implications of additional axioms for morphisms, particularly in distinguishing between unital and non-unital rings. There is an acknowledgment of the need for clarity in definitions and the structure of categories.
algebrat
Hi, I'm looking for intuition and/or logic as to why we would want or need morphisms according to axioms in category theory, to imply that in the category of rings, they must preserve the identity (unless codomain is "0").
Thank you very much.
Okay, I think I thought it was more complicated then it was. I'm sure I was interested for some specific reason, but I guess morphism in concrete categories are just structure preserving functions (I do not have an in depth source to check yet). So the identity part is as Artin says, there aren't necessarily a lot of inverses, so we need to explicitly mention that 1 maps to 1. f(x)=f(x)f(1)→f(x)(1-f(x))=0. For instance we are not in an integral domain so we should require that f(1)=1. Okay, now that I write that, I don't get it. Are all morphisms by definition, in categroy of rings with identity, necessarily taking identity to identity, or is this a stronger restriction that Artin has requested, as opposed to definition of morphism.
The way I understand it, if the category itself demands that all its members have multiplicative identity, then the morphisms will have to respect that. Otherwise, the image of your morphism may not be in the category any longer. If you are in the category of rings without 1 (Pseudo-rings, Rngs), then you aren't restricted this way.
I am still working on categories myself, so others may be able to give you a deeper explanation.
I'm still not 100% certain what your question is, so first I'll give my interpretation of the question.
I believe you are asking why the axioms of general ring homomorphism (f(x)f(y)=f(xy) and f(x)+f(y)=f(x+y)) imply the additional axiom of ring homomorphism for unital rings (f(1)=1), in the case that both rings have a unit.
If this is your question, then the simple answer is that they don't. A general ring homomorphism R→S actually does not need to be a unital ring homomorphism just because R and S are unital. For instance, the zero function between any two rings is a (pseudo-)ring homomorphism, but it is never a unital ring homomorphism unless the codomain is the zero ring (since we would need 0=1).
Put in other words, the category of rings is a subcategory of the category of pseudo-rings. However, it is not a full subcategory.
Another interpretation of your question is "Why do we include this additional axiom f(1)=1 explicitly?"
If that's what you meant, then the answer is essentially the same. It's because it's not implied by the other ones.When we're talking about a concrete category of algebraic objects, a full subcategory basically corresponds to the case that no new axioms of homomorphism are necessary. Since the "extra structure" (the unit) is not automatically preserved, we need two things:
1. On the algebra side, we add an extra rule to our homomorphism.
2. On the categorical side, we cut out the morphisms that didn't satisfy that rule, making our subcategory no longer full.
Thank you!
Yes, very nicely said.
To be sure, I was thanking you equally Sankaku!
  • · Replies 0 ·
  • · Replies 26 ·
