| New Reply |
Are we travelling slower through time due to the Earths orbit? |
Share Thread | Thread Tools |
| Jun12-12, 08:37 AM | #1 |
Is it that faster we move through space, the slower we move through time?
Is it that we're moving slower through time than if the Earth wasn't orbiting anything? And on a wider scale like, the Sun orbiting the centre of our galaxy, and our galaxy moving through space. How would time be different if we weren't moving in space? We must be moving at a fair pace through space with all this orbiting going on. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun12-12, 08:42 AM | #2 |
Slower for whom?
All motion is relative so the question is not trivial to answer. For someone on a space ship that was not orbiting the Sun (just hanging there and using its engines to cancel out the Sun's pull) then clocks on Earth would appear to be going slower than the ship-board clocks. BUTTTTT, to an observer on Earth, the ship's clocks would also appear to be going slower than the Earth clocks. This is a consequence of Special Relativity. The clocks would only agree if the ship were also in orbit, parallel to the Earth. |
| Jun12-12, 08:47 AM | #3 |
There's a contribution of special relativity that causes time to move slower in the earth frame with regard to the sun frame. However, there's an opposite effect due to general relativity which causes time to move slower in the higher gravity in the frame of the sun. You can calculate both effects.
This is also a significant matter with regards to the GPS system. Here, the contribution of general relativity is greater if I recall correctly. |
| Jun12-12, 08:51 AM | #4 |
| Jun12-12, 08:59 AM | #5 |
One minute per minute!
| Jun12-12, 09:00 AM | #6 |
I don't get it.
| Jun12-12, 09:06 AM | #7 |
Then perhaps you should explain what you mean by "moving through time".
| Jun12-12, 09:12 AM | #8 |
| Jun12-12, 09:22 AM | #9 |
I don't know if that makes any sense. How fast are we moving through time is my question. |
| Jun12-12, 10:04 AM | #10 |
The point is that everyone has their own, personal clock, the speed of which is governed by how fast they are going relative to other things and people and how near they are to other objects with mass. Two people, side by side will agree that their own clocks are synchronous. The more different their position and relative speeds, the greater is the disagreement between their two clocks. Time is no more absolute than position or velocity - it's just a general consensus of people here on Earth - and even that's not exact. |
| Jun12-12, 10:16 AM | #11 |
Recognitions:
So if you want to see how quickly something is moving through time, that's easy - attach a clock to it and let the clock tell you. But you started with a different question, are we moving more slowly through time because of the Earth's orbital motion.... |
| Jun12-12, 10:20 AM | #12 |
I guess its relatively relative. If you measure the speed of a bird in a moving car, and then from the ground, both will yield very different results. But we need to define what 'Speed' or 'Rate' first to apply it in 'time's' case. According to me, it is The change of a position/value of variable with respect to the change of another variable whose speed is constant in the observer's frame. When both variables are of same physical quantity, but of different frames, we get a ratio. For Example, When the car moves through a distance X, the bird moves through a distance Y. Here the Change of position of the Bird w.r.t the change of position of car = Y/X. Now, when we come to Speed: When the bird moves through a distance of Y, the time in the car moves through a gap of 2 seconds. Here, the Change of position of bird w.r.t the change of position of time in the car = Y/2 m/s. Let us come to the (Speed/Motion/Rate of Travel) of Time. If you put a LARGE Digital Clock on Mars, and an accurate atomic clock on Earth, then you can find a "Ratio" buy using a telescope and omitting any speed-of-light errors. When the time on mars changes by 2 seconds, the time on earth changes by 2.000...001 Seconds. So, the ratio here comes to about: 1.0000...05. Now there are 2 speeds of time, one is Mental, and the other is Physical. Mentally, when your brain processes increase/decrease speed of time can change. Physically, we need to find our "Change of Our Position Through Time" and "The change of position of Time" during the same interval. Since we are trying to finding the change of position of Time in OUR reference w.r.t. the change of ABSOLUTE time, its a ratio. ALL ratios are relative until you set an ABSOLUTE reference frame for yourself, in our case, THE EARTH. Hence, you are travelling through time as fast as Earth is, you are up to speed! Otherwise, you will have to find another Variable whose change is constant w.r.t to another variable whose.... and the loop goes on.(if you get what i mean, and most likely you havent, my english isnt good) The aim of this long post was to Signify how difficult it can be to find a speed of time. |
| Jun12-12, 10:40 AM | #13 |
| Jun12-12, 10:46 AM | #14 |
| Jun12-12, 10:55 AM | #15 |
| Jun12-12, 11:54 AM | #16 |
I agree your opinion on those ratios. I guess the asker has achieved a satisfactory answer. |
| Jun14-12, 11:33 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Are we travelling slower through time due to the Earths orbit?
| General Relativity: Particle velocity travelling on Schwarzchild orbit | Advanced Physics Homework | 0 | ||
| Orbital mechanics: Accelrating takes you into a slower orbit? | Classical Physics | 19 | ||
| Slowing down the earths rotation and changing the moons orbit | General Physics | 10 | ||
| Why does a travelling twin age slower but not get shorter? | Special & General Relativity | 40 | ||
| Earths orbit around the sun | Astrophysics | 5 | ||
