Are there two types of mass in modern physics?
  • Context: Graduate
  • Thread starter Thread starter david findley
    Mass
The discussion revolves around the concept of mass in modern physics, particularly whether there are two distinct types of mass. Participants explore the implications of the Higgs mechanism for elementary particles and the relationship between mass and energy, especially in the context of photons and their gravitational effects.
  • Some participants propose that mass for elementary particles arises from interaction with the Higgs field, while others argue that photons, despite having energy, do not possess mass in the traditional sense.
  • A participant presents the relationship between mass and energy using the equation E = γ mc², suggesting that mass can be derived from energy in certain frames.
  • Another participant questions the nature of gravity, asking why photons, which are considered massless, still exhibit gravitational effects.
  • Some participants differentiate between inertial mass and gravitational mass, noting that both types are equivalent according to the equivalence principle.
  • It is mentioned that general relativity uses the energy-momentum tensor as the source of gravity, implying that energy (including that of photons) contributes to gravitational effects.
  • A distinction is made between rest mass and relativistic mass, with a suggestion that modern physics typically refers to rest mass, while relativistic mass is less favored due to potential confusion.
Participants express differing views on the nature of mass, particularly regarding photons and the distinction between types of mass. There is no consensus on whether there are two types of mass or how to categorize photons in this context.
Some participants note the potential confusion surrounding the terms "rest mass" and "relativistic mass," indicating that the discussion may depend on definitions and interpretations that are not universally agreed upon.
david findley
hello,
in my studies (of popular physics texts written for the lay-man, and wikipedia,) I have a question:
it seems that mass for many elementary particles is the immediate consequence of interaction with the higgs field, via the higgs mechanism
but there are other particles that can be considered as having mass, such as photons, per einsteins Mass-Energy Equivalence Principle. That is, because photons can be considered as having energy, then they can simultaneously be considered as having mass, as well.
and so, I ask, does this mean that there are two types of mass?
I don't know what to think :O( can anyone clear this up for me?
The mass m and the energy E are two parameters related by
In any given Galilean frame (for which the particle may be moving),
E = γ mc2
where γ = 1/ √(1-v2/c2))
Thus
m = (what would E appear to be relatively to the particle itself) / c2.
The law of conservation of energy is that in any fixed referential, the sum of all energies is constant.
Thus a collision of two photons, that have nonzero energy but zero mass, will produce something with nonzero mass (from to the sum of energies of both photons that are equal to each other in the involved frame) which can then annihilate again giving back 2 photons as started.
Thus mass is not conserved.
I see, so are you saying that the photons do not have mass, but rather that their energy values can create mass, (ie as in collisions.)
hmm, ok... So, if photons do not have mass, then why do they have gravitational fields?? I thought that only things with mass have gravity... but I know that light has gravity, too...
so why does light have gravity if it does not have mass??
That what Newton said. Mass and gravity.
Then came Einstein said that it is gravity and space.
The light just follow the line, which by gravity effect make the line crooked or bend.
This does not address your question regarding "relativistic mass" of photons, but there are two kinds of mass: inertial mass, which is the mass required to produce a certain Newtonian acceleration given a certain force, and gravitational mass, which is the mass required to produce a certain gravitational acceleration with a given gravitational mass. As far as we know, inertial mass = gravitational mass. This is called the equivalence principle.
General relativity uses the (stress-)energy-momentum tensor as source of gravity. Photons have energy. Nothing wrong there.
You can relate the energy to something which can be called gravitational mass. But it is fine to work with the energy only.
I think you (the OP) are referring to the rest mass of a particle and the relativistic mass of a particle in relative motion. In modern physics mass is usually the former i.e. it is the amount of stuff present in the rest frame of the particle. In this context things like photons have no mass. Relativistic mass is used in older texts but has fallen out of favour because it can be confusing, relativistic mass is kinetic energy. It is still used in particle physics where the mass-energy is given in electron volts.
Photons although they have no mass gravitate as all energy does because it is the stress-energy tensor that creates the curvature of spacetime not the mass.
  • · Replies 19 ·
