Why partial derivatives in continuity equation?
The continuity equation, represented as \(\frac{\partial \rho}{\partial t} = - \nabla \vec{j}\), employs a partial derivative with respect to time to account for the spatial variability of charge density (\(\rho\)). This choice is rooted in the derivation from the equation \(\frac{dq}{dt} = - \int\int \vec{j} \cdot d\vec{a}\), which indicates that charge density can change not only over time but also across different spatial locations. The use of a partial derivative reflects the necessity to isolate the time-dependent changes while acknowledging the influence of spatial factors on charge density.
  • Understanding of vector calculus, specifically divergence and gradient operations.
  • Familiarity with the concepts of charge density and current density in electromagnetism.
  • Knowledge of differential equations and their applications in physics.
  • Basic grasp of the principles of continuity in fluid dynamics or electromagnetism.
  • Study the derivation of the continuity equation in electromagnetism.
  • Explore the implications of using partial derivatives in fluid dynamics.
  • Learn about the divergence theorem and its applications in charge conservation.
  • Investigate the relationship between charge density and current density in various physical contexts.
Physicists, electrical engineers, and students studying electromagnetism or fluid dynamics who seek to deepen their understanding of the continuity equation and its mathematical foundations.
biubiu
Why is partial derivative with respect to time used in the continuity equation,
[tex] \frac{\partial \rho}{\partial t} = - \nabla \vec{j} [/tex]
If this equation is really derived from the equation,
[tex] \frac{dq}{dt} = - \int\int \vec{j} \cdot d\vec{a}[/tex]
Then should it be a total derivative with respect to time?
Partial derivative is used because the charge density may also vary with distance.
  • · Replies 20 ·
  • · Replies 32 ·
