Understanding the Relationship between Nonlinearity and Dispersion in Materials
  • Context: Graduate
  • Thread starter Thread starter b3824855
    Dispersion
The discussion revolves around the relationship between nonlinearity and dispersion in materials, particularly focusing on whether a nonlinear (specifically second-order) material can be non-dispersive. Participants explore the implications of this relationship in the context of simulations involving second harmonic generation (SHG) and optical rectification (OR).
  • One participant questions if a nonlinear material can be non-dispersive, noting that their simulations yield different results when using dispersive versus non-dispersive materials.
  • Another participant asks for clarification on the difference between dispersive and dissipative materials.
  • Some participants propose that nonlinearity and dispersion may be independent, suggesting that phase matching is crucial for SHG and could explain the simulation results.
  • A participant explains that in a non-dispersive medium, both frequency components (ω and 2ω) would travel at the same velocity, which they believe should facilitate phase matching.
  • Another participant suggests considering a nonlinear dissipative term to achieve nonlinearity and references Duffing's equation as a potential resource.
  • One participant mentions that Boyd's 'Nonlinear Optics' indicates that perfect phase matching in a dispersionless medium should lead to a consistent increase in the second harmonic signal.
  • Optical rectification is described as requiring only a single frequency and should also function normally in a dispersion-free medium.
Participants express differing views on the independence of nonlinearity and dispersion, with some agreeing that they are independent while others remain uncertain. The discussion does not reach a consensus on the implications of these relationships for the simulation results.
Participants highlight the importance of phase matching in nonlinear optical processes and the potential complexities introduced by different material properties. There is mention of the need for further exploration of the simulator's workings and the mathematical framework involved.
This discussion may be of interest to those studying nonlinear optics, materials science, or anyone involved in simulations of optical phenomena, particularly in relation to SHG and OR.
b3824855
Hello All,
My question is "What is the relationship between nonlinearity and dispersion?"
I know that all materials are dispersive in nature, but keeping that aside for a moment and thinking of an ideal material, can I have a nonlinear (2nd order to be exact) material which is nondispersive? (Refractive index does not change with frequency)?
Iv been trying to implement such a material in a simulator, but I am not getting any second order nonlinear interactions such as SHG or OR when I use this material. The same simulation with dispersive materials gives SHG and OR.
Can some one please tell me the reason for this? Thank you very very much.
Science news on Phys.org
Are you clear as to the difference between dispersive and dissipative?
b3824855 said:
Hello All,
AFAIK, they are independent from each other. I'm not sure how your simulator works, but second harmonic generation requires phase matching, so that may be why omitting dispersion causes problems. I don't know what OR stands for.
Hi,
@Studiot -> I am referring to a material whose refractive index does not change with frequency. i believe this is called non -dispersive, (i don't think that this has anything to do with dissipative)
@ Andy -> Yes, I thought that the non linearity and the Dispsersion were independent too. Thats why I was baffled with the simulator results.
As you said, Second Harmonic Generation requires phase matching between the individual frequency components ω and 2ω. Which means both these frequencies must travel at the same velocity inside the material. When the refractive index does not change with freq, the velocity of both freq would be c/n inside the material. Where n is the refractive index. So, I had thought that this would be a perfect phase matching scenario! Wouldnt it be? :confused:
What do you think?
Thanks for the replies. Btw, OR stands for Optical Rectification. (its a similar process to SHG, but the generated freq, is not at 2ω. but at 0).
Sorry but my knowledge of optics, whether classic, wave or quantum, is limited.
From what you say you do not want to include a dispersive term (ω is therefore constant) to make your equations non linear.
Another way to make you equation non linear is to introduce a non linear dissipative term.
Therefore I suggest you consider Duffing's equation.
Chapter 7 of
Non linear Ordinary Diffrential Equations by Jordan and Smith
may well cover your needs.
b3824855 said:
Hi,
<snip>
What do you think?
I don't know how your simulator works, so I can't really comment on why you are getting odd results.
In any case, scanning Boyd's 'Nonlinear Optics', assuming perfect phase matching (which seems to be similar to a dispersionless medium) results in a monotonically increasing second harmonic signal. Optical rectification only requires a single frequency (other than a zero-frequency) and should also behave normally for a dispersion-free medium.
Thanks, I'll have a look in Boyd's nonlinear optics.
31K
