Axial Flux PMG Testing for 100W Wind Turbine - William
The discussion focuses on testing an axial flux permanent magnet DC generator designed for a 100W wind turbine to charge 12V batteries. The user, William, initially conducted no-load tests using a lathe machine, measuring open circuit voltage and short circuit current up to 500 RPM. Recommendations include using a 12V lead-acid car battery as a load to safely measure power output, as it can handle voltages between 9-16V and accept high charging currents. A scatter plot of voltage and current measurements versus RPM will provide insights into the generator's performance.
  • Understanding of axial flux permanent magnet generator design
  • Familiarity with basic electrical measurements (voltage, current, power)
  • Knowledge of battery charging characteristics, specifically for lead-acid batteries
  • Experience with data analysis techniques, such as scatter plotting
  • Research methods for safely testing DC generators with lead-acid batteries
  • Learn about battery management systems for monitoring voltage and current
  • Investigate data visualization techniques for analyzing generator performance
  • Explore alternative load options for testing power output in small-scale generators
Engineers, hobbyists, and researchers involved in renewable energy projects, particularly those focused on small-scale wind turbine design and testing.
W R-P
Hey everyone.
I've been working on a axial flux permanent magnet DC generator to use on a 100W wind turbine(small I know), to charge 12v batteries in low wind speed areas. Now that it's complete, I'd like to determine the full power curve at different rpms.
So far I've been running it on NO LOAD,using a lathe machine as a prime mover. My results from this were the open circuit voltage and the short circuit current at various rpms- up to about 500rpm. i doubt multiplying the two readings will give me a TRUE value of the power I should expect.
I then tried using a dc bulb as a load, but the only available ones are 9w at 12vdc. If my voltage goes way above 12..it will blow,so that test won't go on for long. No power transducer available either..
My question is is there any simple experiment I can carry out to determine the power output, and what kind of load should i use?
some helpful data
STATOR
1.4mm wire
80 turns
6 coils
star connection, passed on to two block rectifiers
Any input would be appreciated.
William
You are correct, open circuit voltage times short circuit current is a meaningless quantity.
For your test, I would use a 12 V lead acid car battery. Short term, it can tolerate 9-16V, and it can accept charge at 50 amps or more. That's far above your 100 w design limit.
For maximum current, start with a discharged battery with open circuit voltage of 11 V.
As the battery state changes, you'll get a scattering of V & I measurements and a P value for each. A scatter plot of those versus RPM gives the generator capability.
For safety, enclose the battery in a battery box able to contain acid in case of battery failure.
  • · Replies 27 ·
