Finding the Volume of Methane at the Given Conditions
The discussion centers on calculating the heat of fusion of water at -10 °C using the heat of combustion of methane (CH4) at 890.4 kJ/mol and the heat capacities of water at 75.2 J/mol·K and 37.7 J/mol·K. The participant, Ahaan, expresses confusion regarding the necessary density of methane, which is not provided in the textbook. The consensus is that the problem lacks sufficient conditions for a clear solution, indicating it may be a challenge problem without adequate context.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with the properties of methane (CH4) and water (H2O).
  • Knowledge of heat capacities and their applications in calculations.
  • Basic skills in problem-solving for chemistry-related homework problems.
  • Research the density of methane (CH4) for accurate calculations.
  • Study the concept of heat of fusion and its significance in thermodynamics.
  • Learn how to apply heat capacity values in thermodynamic equations.
  • Explore common challenges in thermodynamics problems and strategies for solving them.
Chemistry students, educators, and anyone involved in thermodynamics who seeks to understand the calculations related to heat transfer and phase changes in substances.
ahaanomegas
Long title, I know! :-p
The heat of combustion of methane ([itex]\text{CH}_4[/itex]) is [itex]890.4 \ \text{kJ/mol}[/itex] and the heat of capacity of [itex]\text{H}_2\text{O}[/itex] is [itex]75.2 \ \text{J}/\text{mol}\cdot\text{K}[/itex] and that the heat capacity of [itex]\text{H}_2\text{O}[/itex] is [itex]37.7 \ \text{J}/\text{mol}\cdot\text{K}[/itex], calculate the heat of fusion of water at [itex]-10 \ { }^{\circ}\text{C}[/itex].
I really don't know. I'm truly confused.
From the given information, I was thinking of finding the mass of methane, but then I would need the density of methane, which was never mentioned in my textbook. So I highly doubt my thoughts are even on the right track.
Any start/hint to a solution would be highly helpful and appreciated!
Thanks in advance,
~ Ahaan.
This problem should be restated. As it is stated, it does not make sense. You have stated any conditions.
Ah. Now I don't feel so guilty for not getting it. It was a challenge problem in my textbook, so I didn't make it. Sorry about that and thanks! End of thread.
18K
