How do you represent a dependent current source in a parallel circuit using KCL?
  • Thread starter Thread starter DaVinci
    Kcl Kvl
The discussion focuses on the representation of a dependent current source in a parallel circuit using Kirchhoff's Current Law (KCL). The dependent current source is defined as Vo/2000, and the circuit includes a 6k ohm resistor, a 1k ohm resistor, and a 2k ohm resistor, along with an independent current source of 2mA. The correct KCL equation is established as Vo/2000 - Vs/6000 - Vs/3000 + 2/1000 = 0, leading to the relationship Vo = 2Vs/3, which resolves the problem of finding Vo accurately.
  • Understanding of Kirchhoff's Current Law (KCL)
  • Familiarity with dependent and independent current sources
  • Knowledge of voltage dividers in electrical circuits
  • Basic circuit analysis techniques
  • Study the application of Kirchhoff's Current Law in complex circuits
  • Learn about dependent sources and their role in circuit analysis
  • Explore voltage divider circuits and their calculations
  • Practice solving parallel circuit problems with mixed sources
Electrical engineering students, circuit designers, and anyone involved in analyzing parallel circuits with dependent sources.
DaVinci
Quick question that is throwing me off...
If you have a dependent current source in a parallel circuit, how do you represent that in your KCL equation? The one in this problem is Vo/2000.
I took that as I=V/R so R=2000. Since it is in a parallel circuit on its own 'branch' I used Vs/2000. But when I plug it all into the equations, the answer is wrong.
The circuit is this...
Parallel circuit with 4 branches. The following are the branches from left to right.
1. Dep. Current Source = Vo/2000
2. 6k ohm resister with + on top. (Marked also with Vs).
3. 1k ohm resister and a 2k ohm resister. Vo is indicated across the 2k ohm. The + sign is between the two resisters and the - is at the bottom of the 2k ohm.
4. indep current source at 2mA.
I took Vs to be the voltage across each branch since they are all in parallel and it is stated that Vs is across the 6k ohm resister. I tried to do the...
Vs/2000 + Vs/6k + Vs/3k + 2mA = 0
and then solved for Vs which ended up being 2V. Then used that to find Vo... except it is way off as the answer says Vo is 8V.
So, I am either screwing up the representation of the Vo/2000 in the equation or I am screwing up the entire KCL for the equation.
If someone could give a hint, Id appreciate it.
Your mistake was the V/R thing for branch 1.
Branch one is an dependent current source whose value is Vo/2000. No ohm's law trickery is necessary.
Therefore KCL at node Vs is:
Vo/2000-Vs/6000-Vs/3000+2/1000=0 (using your sign convention)
You can relate Vs to Vo by noting branch 3 is a voltage divider.
Therefore:
Vo=2Vs/3
I am sure you have it from here...
Yes, that did the trick.
Thanks!
