Spacetime interval formula - what's the d?
The discussion revolves around the interpretation of the spacetime interval formula, specifically the meaning of the 'd' in the equation ds² = c²dt² - dx² - dy² - dz². Participants explore whether 'd' represents a differential or an infinitesimal change, and how this relates to the concept of delta (Δ) as used in physics. The scope includes conceptual understanding and the implications of calculus in interpreting the formula.
  • One participant suggests that 'd' is the differential form of the spacetime interval, indicating very small (yet nonzero) variations.
  • Another participant questions the clarity of this explanation, indicating a lack of understanding of the calculus involved.
  • It is proposed that for special relativity, the 'd's can be thought of as deltas, allowing for the formula to be used without needing small variations, although this does not apply in the presence of gravity.
  • One participant argues that the use of 'd' implies changes due to forces, which complicates the interpretation of the formula in the context of relativity.
  • There is a disagreement about the appropriateness of using 'd' in the formula, with one participant asserting that it should not be used while another defends its inclusion for infinitesimal changes.
Participants express differing views on the interpretation of 'd' versus Δ, with no consensus reached on whether 'd' should be used in the context of relativity or what it fundamentally represents.
The discussion highlights the dependence on calculus for a deeper understanding of the spacetime interval formula, as well as the ambiguity surrounding the implications of using 'd' in the context of forces and changes in spacetime.
NanakiXIII
I got this formula for calculating the distance between spacetime intervals at Wikipedia:
ds^2 = c^2dt^2 - dx^2 - dy^2 - dz^2
Now first I thought the d was supposed to be the Greek delta which my physics teacher uses to indicate a difference of the following variable, instead of just a simple value, but when looking at other sites, I saw they also used the d. So my question is, is this the same as the delta?
Secondly, I was wondering if someone could explain this formula to me. I understand what it says (if the d is indeed what I thought it was - the delta), but not why this is the formula.
Astronomy news on Phys.org
That's the differential/infinitesimal for of the square of relativistic interval,that's it...So [itex]\Delta[/itex] goes into [itex]d[/itex] each time very,very small (YET NONZERO) variations of the argument are considered...
Daniel.
Thanks for replying, but...I'm afraid I have no idea what you just said.
Then wait until u'll learn (differential) calculus and everything will become amazingly simple...
Daniel.
EDIT:Yeah,good idea,RAHITICAL DELTA... :smile:
As long as you haven't learned calculus, just think of it as a tiny "delta".
Thanks, arildno.
Is it impossible to understand the answer to my second question without knowing this calculus?
In general, the 'd' means that the deltas have to be small for the formula to work correctly.
Fortunately for you, in special relativity, when space-time is flat, the deltas don't even have to be small. So you can use the above formula "as-is", by thinking of the d's as deltas, as long as you are dealing only with special relativity. (This won't work if there is gravity involved, however, so some other more complicated formulas you see in notation simlilar to the above won't necessarily work with large detlas).
To quantify the notion of "how small does small have to be?" in the more general case, you'd probably need to learn some calculus.
d versus delta
Hi Nana
Your question deals with 'relativity' and as I understand it NO d's are allowed ---- the reason being that it implies changes due to forces .
The normal equation has NO d's and just states the relations in 4 dimensional space , time and distance caused by the property of light.
Under very mild accellerations ( ones which do not imply a lot of mass ( per E=m.c^2) ) then you can allow small variations --- so the 'd' represents small changes in all variables and as such means a very complex situation
because no -one has stated HOW such variables are changing .
In other words IFFF you introduce 'd' meaning samll changes it automatically implies there is a reason for the change -- But NOT stated .
Special relativity does not really try to deal with this -- General relativity does -- but that is a whole different game -- if you are up to it . Ray
rayjohn01 said:
Hi Nana
WHAT??Jesus,what are u talking about?What forces...?
What??It has delta for finite variations and "d" for infinitesimal ones...What's "normal"??
Daniel.
28K
  • · Replies 22 ·
  • · Replies 141 ·
10K
  • · Replies 16 ·
  • · Replies 20 ·
