Calculating Stresses due to Bending and Shear Stresses.
  • Thread starter Thread starter sgvaibhav
    Bending Shear
This discussion focuses on calculating stresses due to bending and shear in a pipe assembly. The key equations involved are σ = P/A + Mc/I for normal stress and τ = Tc/J + VQ/It for shear stress. The user is specifically struggling to determine σx, σy, and τxy at point H on the pipe's outer surface, given the dimensions of the pipe (inner diameter of 38 mm and outer diameter of 42 mm) and applied forces. A correction was suggested regarding the user's moment calculations, emphasizing the importance of accurate unit notation.
  • Understanding of stress and strain transformations
  • Familiarity with bending and shear stress equations
  • Knowledge of moment calculations in structural analysis
  • Ability to interpret mechanical diagrams and forces applied to structures
  • Review the derivation and application of the equations for normal and shear stresses
  • Study the concept of principal stresses and their calculation methods
  • Learn about the Mohr's Circle for visualizing stress states
  • Explore resources on common mistakes in stress analysis and unit notation
Mechanical engineers, structural analysts, and students studying mechanics of materials who need to understand stress calculations in pipe assemblies and similar structures.
sgvaibhav
Hi.
I am solving some questions on transformations of stress and strain.
I am getting stuck in one part of the question in all the problems.
I am having difficulties to determine σx, σy, τxy at a certain point in the structure.
Equations
σ = P/A + Mc/I
τ = Tc/J + VQ/It
Some components, or the entire stress can be zero depending on the question.
I will post one of the example questions where i am facing difficulty.
Question) [Picture attached] Several forces are applied to the pipe assembly shown. Knowing that the inner and outer diameters of the pipe are equal to 38 mm and 42 mm, respectively, determine (a) the principal planes and the principal stresses at point H located at the top of the outside surface of the pipe, (b) the maximum shearing stress at the same point.
My Difficulty - I know how to do the most of the question EXCEPT - finding σx, σy, τxy at a point H and/or point K.
Working- [ I think it should be correct]
Fx=0
Fy=0
Fz=0
Mx=T=-200x200mm = 40N.m
My=-200x300mm = 60N.m
Mz=48N.m
Next step find σx, σy and τxy at point H in this case.
After finding the stresses, i can solve the rest of the question.
Please share resources, or links to the concept of finding stresses if you are short of time.
sgvaibhav: Your Fz and My currently look incorrect. Try again. Also, use your relevant equations to make an attempt to compute one or more of the stresses. There is no point K.
By the way, always leave a space between a numeric value and its following unit symbol. E.g., 40 N*m, not 40N*m.
