| New Reply |
Using gnuplot through a pipe in C/C++ to generate multiple plots (one each iteration) |
Share Thread | Thread Tools |
| Jun19-12, 07:23 AM | #1 |
Hi,
So I'm trying to solve the 2D Ising Model using a simple Monte Carlo algorithm, for small square lattices, imposing periodic boundary conditions. Before I compute any thermodynamic quantities though, I want to study the energetics of the system with only nearest-neighbour interactions. I want to visualize the system at every iteration of the Monte Carlo loop. The idea is to store the state of the lattice in a matrix, with each site storing the value +1 for spin up, and -1 for spin down. A computer program I've written in C with a friend generates a data file with the state of the matrix. I then use a pipe to call gnuplot from within this program, to plot the file. However, I notice that the plot window appears only after the pipe is closed -- presumably it is then that gnuplot is actually executed the first time, with all the arguments sent through the pipe. This means the plot window does not show up at a specific time of your choice, and in fact shows up at the end of the program. Now, I want to visualize the matrix at every iteration, so for that, I need to call gnuplot (through the same pipe pointer) in every iteration, so that the existing plot is updated. How can this be done? If I just naively include a plot command (through fprintf), then the plot shows up for the first time after some 20 or 30 iterations (depending on the size of the lattice). Thanks in advance! |
| Jun19-12, 10:36 AM | #2 |
you may need to flush the pipeline. If the C output is buffered, it will only be written when the buffer is full, or when the file/pipe is closed. You can manually trigger the flushing using fflush(file handle). Otherwise there may be a flag to open the pipe in an unbuffered mode.
| Jun19-12, 10:44 AM | #3 |
Code:
glibc detected *** ./ising: corrupted double-linked list: 0x000000000093e000 *** |
| Jun19-12, 03:46 PM | #4 |
No clue. Make sure Gnuplot exits normally (send exit command) before you kill the pipe?!? Otherwise throw in a hand full of print commands to see how far it goes and where it hangs.
| New Reply |
| Tags |
| gnuplot, ising model |
| Thread Tools | |
Similar Threads for: Using gnuplot through a pipe in C/C++ to generate multiple plots (one each iteration)
| Using multiple variables to generate a table or csv | Math & Science Software | 0 | ||
| Multiple 2D plots in Mathematica | Math & Science Software | 1 | ||
| Radial Plots and Smooth Density Plots | Math & Science Software | 0 | ||
| Contour Plots in Gnuplot | Math & Science Software | 1 | ||
| graphing implicit/3d/whatever (multiple plots) in maple/other software | Calculus & Beyond Homework | 0 | ||
