Graphing a standard quadratic equation?
The discussion revolves around the methods for graphing a quadratic equation, specifically in the standard form ax^2 + bx + c = 0 and its vertex form. Participants explore various techniques for sketching the graph, including identifying roots, intercepts, and the vertex of the parabola.
  • Homework-related
  • One participant asks how to graph a quadratic equation and mentions the form f(x) = [(x + b/2a)^2 - (D/4a^2)], where D = b^2 - 4ac.
  • Another participant suggests that the equation should be in the form ax^2 + bx + c = y and recommends using graphics calculators or freeware graphing software for ease of graphing.
  • A different participant offers a method for hand sketching the graph by finding the roots and y-intercept, and recognizing the second form as "turning point form" for easier sketching.
  • Another contribution emphasizes determining the minima/maxima and zeros of the function to graph it, noting the parabolic nature of quadratics.
  • One participant provides a detailed approach to completing the square to find the vertex of the parabola, explaining how the sign of 'a' affects the direction the parabola opens.
Participants present various methods for graphing quadratic equations, but there is no consensus on a single approach. Some focus on graphical software, while others emphasize hand-drawing techniques and mathematical transformations.
Some methods rely on specific assumptions about the form of the quadratic equation, and the discussion does not resolve which method is preferable for different contexts.
Kartik.
How do we graph a quadratic equation in the form ax^2+bx+c =0?, or an equation like , f(x)(or y)= [(x+b/2a)^2 - (D/4a^2)], where D = b^2 - 4ac? or how do we get a parabolic curve intersecting at its roots(of the quadratic equation) in the x axis?
Mathematics news on Phys.org
Do you mean an equation of the form ax^2+bx+c =y? Anyway, in any case, you can make graphs quite easily on any graphics calculator, or you could also download some freeware graphing software. I used to use this program:
http://download.cnet.com/Graph/3000-2053_4-10063417.html
It is quite simple, but does a very good job for a freeware program. The other alternative would be to use Microsoft Excel which requires a series of points to which it can draw a smooth line.
Hmm re-reading your question, I'm thinking I may have misinterpreted it. Did you want to know how to sketch it by hand? If so, then you could do it quite easily by finding the roots (by factorizing or quadratic equation) and the y-intercept, and then just draw a smooth curve through the points. In the second form you have mentioned, you could recognize it as "turning point form" (from which the turning point can be read without any calculations) and then finding the y-intercept. This will give you enough for a basic rough sketch.
I think you can graph it yourself by determining the minima/maxima and the zeros of the function. The general form a quadratic takes is parabolic; so it should not be hard to draw it.
Assuming you want to graph the function [itex]y= ax^2+ bx+ c[/itex] (you don't graph a function- to graph you have to have at least two variables) I would start by completing the square:
[itex]y= a(x^2+ (b/a)x)+ c= a(x^2+ (b/a)x+ (b^2/4a^2)- (b^2/4a^2))+ c[/itex]
[itex]y= a(x^2+ (b/a)x+ (b^2/4a^2))+ c- (b^2/4a)= a(x+ b/2a)^2+ c- (b^2/4a)[/itex]
Now I know that the vertex is at (-b/2a, c- b^2/4a). If a> 0, the parabola opens upward, if a< 0, downward.
  • · Replies 19 ·
  • · Replies 16 ·
