New Reply
High Emissivity Paint for Aluminium Surface
Share Thread Thread Tools
Jun23-12, 04:18 AM   #1
Hey,
I am making a furnace....which uses Aluminium material. Does anyone knows a paint which can be used for applying on Aluminium Surface and which works upto 500 degree Celsius and has high emissivity.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Jun23-12, 02:07 PM   #2
Recognitions:
You are making a furnace out of metal? An insulating firebrick or ceramic is the usual choice for high temperatures.
Jun23-12, 03:15 PM   #3
Recognitions:
Gold Membership Gold Member
An aluminum furnace that has a heat-source that can overshoot is in danger of self-destructing/melting. It would be far more prudent to construct the walls with cast iron or sheet steel, and line the firebox with firebrick or ceramic, as marcusl suggests. Muffle-furnaces (high-temp boxes for lab-use) are not made out of aluminum for good reason. A properly lined iron or steel furnace will resist deformation and will last for many years.
Jun24-12, 11:48 PM   #4
The furnace I am making is for low temperature applications ....I am going to use it below 500 Degrees Celsius
New Reply
Thread Tools
Similar Threads for: High Emissivity Paint for Aluminium Surface
Thread Forum Replies
High Temp. Emissivity Painting Mechanical Engineering 0
emissivity of radiation from a surface, Leslies cube Advanced Physics Homework 3
High Emissivity Paint Materials & Chemical Engineering 1
Boltzman Constant, Emissivity and Surface Area of a filament Introductory Physics Homework 1
High emissivity IR paint Materials & Chemical Engineering 5
