| Thread Closed |
the problem of infinite divisibility and how QE sheds some light |
Share Thread |
| Jun24-12, 12:36 PM | #1 |
the problem of infinite divisibility and how QE sheds some light.
QE = quantum entanglement A quanta of energy is considered the smallest possible energy "unit" in the universe. note to readers: the below is hypothetical and could have errors .......of various kinds i have asked this to be moved to philosophy section i think -- the quanta cannot be the "last stop" because that would make quantum mechanics very rigid/limited. it may be the last stop within our understanding of time and space but not within the larger laws/fabric of universe the phrase "problem of infinite divisibility" does not exist in any literature, its simply been coined to give a name to the argument below: Could there be events/changes that require less than a quanta? perhaps one or more of the below: - a photon transferring its energy to two other photons (..like a billiards ball striking two other balls)...where the total energy transferred was just 1 quantum....this quanta must however now must be split into two between the two entangled photons - a change in spin of a photon that requires less than a quanta of energy - a change in momentum or position that requires less than a quanta of energy - a split of a single path into two, or more, paths - even if its a single quanta....its still spread over (though infinitesimally small) time and space..... - or consider a quanta of energy/momentum applied to a photon....the back part of the photon will have slightly more energy (compression) than the front part.......because the quanta cannot be considered perfectly rigid.....however quantum entanglement provide some clues in our quest to resolve this ...... Quantum Mechanics, and the phenomena of quantum entanglement, fits in neatly by giving us some clues about the nature of reality (specially at the sub-atomic level) and telling us that our understanding of discrete, continuous is incomplete |
| Jun24-12, 12:52 PM | #2 |
Zeno Paradox.
| Jun24-12, 01:12 PM | #3 |
i went through Zeno's paradoxes just now and its seems they are different. also Zeno's paradoxes are resolvable without having to make use of quantum mechanics. I am saying/hypothesizing that the issue presented above can be resolved only via quantum mechanics (and phenomena like quantum entanglement)... i.e. there are things beyond the quanta, beyond the smallest unit of energy/particle and quantum mechanics is giving us some hints/clues. |
| Jun24-12, 01:18 PM | #4 |
the problem of infinite divisibility and how QE sheds some lightThere will be much more knowledgeable posters, but i i think i can help with some of the questions. With respect to the observed world, QM is certainly limited in explaining the observed world, almost incomprehensible. Why? The so-called universe isn't made out of classical 'stuff', what makes you think it has to be certain way, instead of the other? By definition no(unless new physics is discovered not similar to QM and its postulates and constants). I will await to see if somebody will bring up virtual particles and their contribution. Correct me if i am wrong, but the word quantum doesn't mean much of anything in physics(beyond just a label for minimum quantity). The energy of a photon(or other particles) is represented by its momentum in eV and photons at certain frequences are more energetic and can easily penetrate solids. If you are asking if there is a smaller unit of energy than Planck's constant(4.135667516(91)×10−15 eV·s) i belive the answer is no. I don't consider this the most noteworthy problem as pretty much everyone recognizes that our understanding of everything is incomplete but the topic is certainly interesting. |
| Jun24-12, 01:19 PM | #5 |
How? I am not aware of any experiement that challenges Planck's constant. To the contrary, it seems to be one of the most solid things in physics and is the basis of all known physics. Edit: On a more phislosophical note, i don't believe motion can take place without quantization(even in principle), so your comparision to Zeno's paradox is justified(if you are questioning it, and not making bold claims). |
| Jun24-12, 01:31 PM | #6 |
| Jun24-12, 01:37 PM | #7 |
| Jun24-12, 01:39 PM | #8 |
i mean.....smaller than quanta in a different form..... for example take quantum entanglement.......it's as if it's showing us a deeper reality that the laws (for example of conservation of mass-energy) can "travel" instantaneously...and it has to be that way.....the law is valid at any point in time-space...as if its a-priori to time-space.... also on a separate note - maybe at the quanta level...position-momentum are same thing......you only need one of them to fully describe all about the particle..... |
| Jun24-12, 01:42 PM | #9 |
thanks for boosting my self-esteem.....so I am thinking what Zeno thought many centuries ago...not bad not bad.... |
| Jun24-12, 01:44 PM | #10 |
| Jun24-12, 01:46 PM | #11 |
discreteness might exit "within" time-space......and continuous....(like the wave-function?)...beyond... |
| Jun24-12, 01:55 PM | #12 |
What is the quantization of spacetime? It has to be one Planck times, right? As part of a worldline in GR. It's much less certain than you think that spacetime exists apriori that which you label wavefunctions. Your question is basically reducible to fields vs observed eigenvalues, and you'd have a hard time if you don't think of the 'entities' as anything more than events. |
| Jun24-12, 01:58 PM | #13 |
well on the pragmatic side..
continuous at least to 10-48 mt and maybe beyond, and maybe continuous. http://arxiv.org/PS_cache/arxiv/pdf/...106.1068v1.pdf planck scale: 1.616 x 10-35 meters |
| Jun24-12, 02:03 PM | #14 |
| Jun24-12, 02:14 PM | #15 |
to clarify..... i guess that.....quantum entanglement (and wave functions ?) might not be "effected" by time-space and exist "beyond/outside" it.....except when we try to measure/detect them....i.e. when we pull them "back" into time-space the relationship between the two entangled photons ...the various laws/phenomena behind it....might be hinting to something apriori time-space |
| Jun24-12, 02:45 PM | #16 |
anyway http://www.esa.int/esaSC/SEM5B34TBPG_index_0.html Quantum Connectivity of Space-Time and Gravitationally Induced De-correlation of Entanglement http://arxiv.org/pdf/0809.1907v1.pdf ...in a curved spacetime using localized operators. We contrast the new formulation with the standard approach and find observable differences for entangled states.... |
| Jun24-12, 03:10 PM | #17 |
I have discarded my hypothesis. thanks for reducing the paths the mind (not photon) must travel. |
| Thread Closed |
Similar discussions for: the problem of infinite divisibility and how QE sheds some light
| divisibility problem | Linear & Abstract Algebra | 1 | ||
| Fun Divisibility Problem | Linear & Abstract Algebra | 14 | ||
| Discovery in Ethiopia sheds new light on history of man: New Haven Register | Social Sciences | 0 | ||
| Proof for infinite divisibility? | General Discussion | 4 | ||
