Calculating Muon Speed Using Lorentz Transformations | Relativity Help
  • Thread starter Thread starter vsage
    Relativity
The discussion revolves around calculating the speed of a muon using Lorentz transformations in the context of special relativity. The original poster presents a scenario involving the muon's lifetime and distance traveled, seeking to understand how to apply the Lorentz transformations to find the speed.
  • Participants discuss the relationship between time and distance intervals for the muon, questioning how to apply Lorentz transformations correctly. There are attempts to derive speed from given parameters, with some participants expressing confusion about the results they obtain.
Some participants have provided hints and guidance on using the Lorentz transformations, while others are exploring the implications of the muon's frame of reference. There is an ongoing exploration of the concepts without a clear consensus on all aspects of the problem.
Participants are navigating the complexities of relativistic effects, particularly the interpretation of time and distance in different frames of reference. There is a noted confusion regarding the application of the transformations and the meaning of certain variables in the context of the problem.
vsage
A muon is an unstable elementary particle with an average lifetime of 2.20×10-6 seconds (from the moment of creation until it decays) as measured by an observer at rest with the muon. If an average muon travels a distance of 900 meters during one lifetime, according to an observer in the laboratory, what is the muon's speed (in m/s)?
I have the Lorentz Transformations sitting right in front of me but I can't seem to make the logical jump again. If O is the observer's frame and O' is the muon's frame of reference I have the following data:
x = ?
t = 2.2*10^6s
x' = 900m
t' = ?
I really don't remember where to go from here. I tried taking the ratio of x to t and x' to t' the Lorentz transformations but it didn't yield anything relevant. Thanks in advance.
I tried using the fact that t' = [tex]\gamma[/tex]t and x' = x/[tex]\gamma[/tex] and v = x/t to yield v = x'[tex]\gamma[/tex]/t but the answer came out imaginary. What am I doing so wrong?
Think in terms of the time and distance intervals between the birth and death of the muon. Here's what you are given:
[tex]\Delta t = ?[/tex]
[tex]\Delta x = 900[/tex]m
[tex]\Delta t' = 2.2*10^6[/tex]s
big hint:
[tex]\Delta x' = 0[/tex]
Now use the LT to find [itex]\Delta t[/itex], at least in terms of v. Then realize that [itex]\Delta x/\Delta t = v[/itex]. Solve for v.
Careful of those "facts". While it's true in this case that [itex]\Delta t = \gamma \Delta t'[/itex], [itex]\Delta x \ne \Delta x' / \gamma[/itex]. Use the full LT; don't take shortcuts (until you have more experience and know when to use them).
Well I got the right answer with your advice (thanks btw) but I don't understand why [tex]\Delta[/tex]x' = 0 still. It should be obvious but I apparently forgot all of relativity.
vsage said:
Well I got the right answer with your advice (thanks btw) but I don't understand why [tex]\Delta[/tex]x' = 0 still. Does that mean it was observed to have barely moved in the time interval or what?
Remember that the primed coordinates are observations made in the "moving" frame attached to the muon. How far does the muon move in its own frame? :wink:
Argh I see now. I completely switched the perspectives. For some reason I thought the decay time was measured from an observer standing on Earth or something. Thank you!
  • · Replies 21 ·
11K
  • · Replies 22 ·
