| New Reply |
How to calculate weight of vehicle with weigh of each wheel? |
Share Thread | Thread Tools |
| Jun26-12, 12:52 AM | #1 |
I'm doing a project regarding weight of vehicle. So we are taking reading of the weight of each of the wheel of the vehicle. So is there any formula to calculate the weigh of the vehicle that has 4 wheel.
For Instance, wheel 1 = x kg and so on and so forth |
| Jun26-12, 02:19 AM | #2 |
As long as each wheel remains at a set height* throughout the measurement, then simply add the four values together.
* Changing the position of any wheel relative to any other wheel induces reactions in the vehicle's suspension/chassis, thus changing the relative weight. If you have only one scale and need to move it for each measurement, place removable platforms (equal in height to the scale) under each wheel. Swap a platform with the scale to take the measurement for that location. |
| Jun26-12, 05:38 AM | #3 |
and disconnect any anti roll bars ( sway bars) and jounce the suspension each time you relocate the single scale
| Jun26-12, 07:41 AM | #4 |
oh. ok. But a problem i found was this as im doing heavy vehicle such as trailer and truck so there might be chances that the weight is not evenly distributed throughout all the wheel. would it affect the reading?
| Jun27-12, 05:37 PM | #5 |
That could definitely complicate the procedure. If you have dual wheels, you will need to devise a platform that evenly distributes the weight of both tires onto the scale's platform. I've not tried it, but I believe tandem axles should be able to be weighed in the same manner I first described. As long as all of the wheel/axle heights remain the same for each measurement, then the load on each axle will remain the same. |
| Jul14-12, 10:17 PM | #6 |
| New Reply |
| Tags |
| formula, formula weight, vehicle, weight |
| Thread Tools | |
Similar Threads for: How to calculate weight of vehicle with weigh of each wheel?
| Calculate the acceleration of a vehicle | General Physics | 14 | ||
| Determining a vehicle's translational acceleration from wheel torque | Engineering, Comp Sci, & Technology Homework | 5 | ||
| calculate wheel torque based on known Weight, wheel size, acceleration data ? | General Physics | 9 | ||
| Turning radius of a ZTR vehicle with two different wheel velocities | Classical Physics | 7 | ||
| how to weigh an object that's heavier than the max. weight of the spring scale | Introductory Physics Homework | 1 | ||
