New Reply
Magnetic field question?
Share Thread Thread Tools
Jun26-12, 03:12 PM   #1
The conductive bar CD with a length of 20 cm and resistance R, moves with speed v=5 m/s. The magnetic field is perpendicular with the plan and the induction is B=2 T.
The mass of the object in the figure is m=80 grams and g=10 m/ s^2
a) find the direction and the intensity of the induced current that moves in CD
b) The resistance of this bar
2. Relevant equations
Figure : http://s1171.photobucket.com/albums/...rent=hrtfg.jpg
3. The attempt at a solution
I tried using Emf=B*L*v and then I=emf/R but i dont know the R..
I JUST WANT TO KNOW HOW TO RELATE Tension and weight with induction//
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun26-12, 03:27 PM   #2
If the bar is moving at a constant speed this tells you something about the resultant force on the bar?
There is a force due to the weight of the mass and there is a force due to any induced current flowing in the wire CD.
Jun26-12, 08:13 PM   #3
Hello Elaia06,
You have to find the induced current first which as truesearch points out bases itself on the fact that the rod is moving at a constant velocity.Tension can be found out basing your derivations on the same fact.Direction of induced current comes out as a result of the same(analyse the forces on the rod and see which direction of current corresponds to equilibrium).Then for resistance you have adequate expressions in your attempt .
regards
Yukoel
Jun27-12, 04:14 AM   #4
Ah, the resultant force is zero.This means the only force acting on the bar is the magnetic force F=B*i*l.
Now we have the Tension= mg-ma but acceleration is zero so we write
Magnetic force = Force on the string
B*i*l=m*g
I know how to solve this now
The magnetic force will have the direction <---- based on the figure and the induced current the direction from left to right .
IS IT CORRECT NOW?
Jun27-12, 04:19 PM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
you haven't used v or R
Jun28-12, 01:08 AM   #6
after i find I, then I use I=b*L*v/R and so I find R :)
Is it correct in total?
Jun28-12, 08:53 AM   #7
Recognitions:
yes, that's correct
Jun28-12, 12:43 PM   #8
Thank you very much sweetheart! :D
New Reply
Thread Tools
Similar Threads for: Magnetic field question?
Thread Forum Replies
Tricky Magnetic Field Question... (Proton Enters Magnetic Field......) Introductory Physics Homework 8
Current carrying wire in uniform magnetic field; where is net magnetic field 0? Introductory Physics Homework 1
Magnetic Field question Introductory Physics Homework 3
Electromagnetic Waves Question, regarding Magnetic Field and Electric Field Introductory Physics Homework 25
Question about a magnetic dipole in an inhomogeneous magnetic field.Please help ASAP Advanced Physics Homework 3
