New Reply
Photoelectric effect vs Compton scattering
Share Thread
Jun26-12, 09:38 PM   #1
I understand that in photoelectric effect, the energy of the whole photon is absorbed, freeing an electron. I don't understand why in the case of Compton scattering, the higher energy photon lost part of its energy instead of transferring the whole of its energy to the electron as in photoelectric effect? Does it mean that there is a limit that the electron could absorb so much energy and no more?
Thanks.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Jun27-12, 04:55 AM   #2
Mentor
Quote by mike168 View Post
Thanks.
These two are very different phenomena.
The photoelectric effect requires the interaction of the WHOLE SOLID. In effect, the whole solid absorbed the energy and "promotes" the electron into the vacuum state.
The Compton scattering is the interaction with the electron itself, and doesn't require either the whole solid or the atom be a part of the interaction. In fact, it could occur with a free electron (photoelectric effect cannot happen in a free electron). So the photo must have a "direct collision" with the electron, which may explain why it is more likely to occur with high energy photons with more "well-defined", shorter wavelength.
Zz.
Jun27-12, 08:36 AM   #3
Recognitions:
Gold Membership Gold Member
For a free electron, there is a very small energy gap (only 'just' finite) between its states so any photon can interact with it. Even low frequency Radio Waves can interact with free electrons (in the ionosphere, for instance) but we usually analyse that effect in terms of how the electrons are affected by the Field rather than the Photons. There must (?) be an alternative way to approach it, though.
Jun27-12, 09:48 AM   #4
Hi guys
Thank you for your reply.
ZapperZ,
I understand that these are very different phenomena. Can you elaborate on what you mean by interaction of the whole solid - in terms of the atomic structure/latice structure? But are they mutually exclusive? If,say, I shine a beam of X-ray onto a metal, could I find BOTH 1 and 2 below:
1. X-ray photons completely passed its energy to an electron, freeing it
2. Compton scattering, with longer wavelengths photons detected (be the probability of this be however small because of the very small chance of direct hitting a bound electron)
If BOTH 1 and 2 could be present at the same time, what determines when the photon would pass part of its energy and when it pass its complete energy to an electron, assume the photon directly hit the electron in both cases.
Jun27-12, 09:49 AM   #5
Mentor
Quote by sophiecentaur View Post
What is the energy gap of a free electron?
Zz.
Jun27-12, 10:40 AM   #6
well, in the photoelectric effect, the photons dont transfer all their energy, which is why the liberated electrons have a range of energies.
But why is light a particle?
1. No time delay in photoelectric emission
2. Increasing intensity of light has no effect, but frequency does
3. Classical resonance does not apply
4. In compton, the freq of the scattered light changes
5. Also, the light appears to be radiated in only one direction, classically it should be in all directions.
Jun27-12, 11:06 AM   #7
Mentor
Both processes are possible. Which one a particular photon produces is basically a random "choice." The probabilities are determined by the interaction cross-sections (or the related absorption coefficients) for photoelectric and Compton scattering, which depend on the photon energy and on the target material.
See here for a typical graph of the absorption coefficients as a function of energy. Click ahead to page 175 if necessary.
http://books.google.com/books?id=8Vu...ctions&f=false
Jun28-12, 01:27 AM   #8
Quote by Michio Cuckoo View Post
In this case the photons do transfer all their energy, the electrons have a range of energies because it is the difference between the photon energy and the ionization energy of the electrons, which varies.
increasing intensity increases the current
Quote by jtbell View Post
Thanks jtbell, this clarifies very much
Jun28-12, 03:16 AM   #9
Quote by ZapperZ View Post
I never read that about the photoelectric effect. The wikipedia page also seems to suggest it is a one-to-one interaction. It says the interaction is between a photon and the "outermost electron". Either the whole energy is absorbed or the photon is reemitted. If part of the energy is absorbed and part emitted, it has another name: the compton effect.
Jun28-12, 05:07 AM   #10
Mentor
Quote by vin300 View Post
In a metal, what is the "outermost electron"? After all, the classical photoelectric effect is done on metallic surfaces! Furthermore, for the description of the photoelectric effect that I mentioned, what is contradicting the notion that the whole photon's energy is absorbed? I never contradicted that!
Wikipedia is confusing photoelectric effect with photoionization done on atoms/molecules. There is a reason why we give these phenomena two different names - they have subtle differences!
I can show you other places where Wikipedia got it not quite right.
Zz.
Jun28-12, 04:06 PM   #11
In the photoelectric effect the whole photon is stopped in the metal. The max energy transferred to an electron equals the energy of the photon, it is misleading to say that the 'whole solid' absorbs the energy and promotes an electron. This was one of the original problems with the photo electric effect.... if the 'whole solid' absorbs the energy then it should take a long time before any single electron gained enough energy to be ejected. In fact there is almost no time delay between the absorbtion of a photon and the ejection of an electron.
I agree about Wikipedia....WHY is it taken as the first choice for an answer.... it explains nothing
Jun28-12, 04:56 PM   #12
Mentor
Quote by truesearch View Post
Think again. The affected electron is the CONDUCTION BAND ELECTRON. A conduction band can only exist due to the formation of a continuous band from not only the overlapping of all the individual atoms, but also the mean-field interaction of all the electrons. In other words, the entire solid.
And when the electron is emitted, the lattice ions (not just ONE ion) has to take up the recoil momentum!
Do you want more? How about this? In the spectrum of the emitted photoelectrons, one can also detect the phonon effects of the solid via the broadening of the electron energy spectrum! It means that the electrons are decisively affected by the many-body effects of the solid!
http://arxiv.org/abs/cond-mat/9904449
Photoelectric effect involves a lot of the solid.
Zz.
Jun28-12, 05:00 PM   #13
Zz.
Zero. Just substitute [itex]\theta = 0[/itex] (forward scattering) in the Compton formula.
Jun28-12, 05:12 PM   #14
Mentor
Quote by Dickfore View Post
But zero isn't "just finite", which is what I was asking in that post.
Zz.
Jun28-12, 05:15 PM   #15
Zz.
I don't understand. What do you mean by "just finite", and where in your post did you ask this?
Jun28-12, 07:16 PM   #16
Mentor
Look at post #3 that I was responding to.
Zz.
Jun28-12, 07:54 PM   #17
Zz.
Well, if you meant that there is no gap for Compton scattering, then you were right.
New Reply
Similar discussions for: Photoelectric effect vs Compton scattering
Thread Forum Replies
Compton effect and Photoelectric effect explained by wave theory? Quantum Physics 4
Difference between Compton effect and Photoelectric effect Quantum Physics 1
Compton vs Photoelectric effect? Quantum Physics 12
Question about Photoelectric Effect versus Compton Scattering. General Physics 4
Compton effect with no scattering angle Advanced Physics Homework 4
