Einstein's Theory of Time: Debunked by Speed and Light | Real-Life Example
  • Context: Graduate
  • Thread starter Thread starter Kristupas
The discussion revolves around Einstein's theory of time dilation, particularly the assertion that time flows slower at higher speeds. Participants explore various interpretations and implications of this theory, with a focus on the relationship between speed, time measurement, and the behavior of light. The conversation includes both theoretical and conceptual elements, with participants presenting examples and counterexamples to illustrate their points.
  • Some participants argue that Einstein's theory is incorrect, claiming that as one speeds up, the clock appears to tick slower, but when stopping, time seems to flow faster due to light catching up.
  • Others clarify that time dilation is observed in another inertial reference frame and that proper time in one's own frame does not change, challenging the initial claims about time flow.
  • Several participants emphasize the constancy of the speed of light across all frames of reference, arguing that the original assertions misunderstand this principle.
  • Some contributions suggest a confusion between time dilation and the Doppler effect, indicating a need for clearer understanding of relativity concepts.
  • There are repeated assertions that the effects of special relativity are not merely due to light travel time delays, countering claims made by others in the thread.
  • Participants express frustration over misconceptions and urge others to learn the fundamentals of special relativity to avoid incorrect conclusions.
Participants do not reach consensus; instead, multiple competing views remain regarding the interpretation of time dilation and the implications of speed on time measurement. The discussion reflects significant disagreement on fundamental aspects of Einstein's theory.
Some claims rely on specific interpretations of reference frames and the nature of light travel, which may not be universally accepted or understood among participants. There are indications of missing assumptions and potential misunderstandings of relativity principles.
Kristupas
Einstein's theory that the faster you go, the slower time flows is not correct. I can give his example. You're standing near a clock. Then, you start speeding up, and what you see, is the faster you go, the slower the clock ticks. When you reach speed nearly that the speed of light, it seems that clock is almost still, because light can't catch up to you. Now imagine you stop. What happens? The light catches you and the time seems to flow faster than normal. If you travel near the speed of light to slow down time, you lose distance. The speed doesn't effect the time flow. Clock is only a tool to measure time.
You are incorrect because you did not understand the basic physics.
The concept of time dilation is the observed time in ANOTHER INERTIAL REFERENCE FRAME. The proper time in your own frame does not change! If the clock moves with you with respect to another frame, then you see NO CHANGE in the clock's time! You detect no time dilation! So that is where you are mistaken!
Furthermore, when you stop with respect to a reference frame, you are decelerating, and another set of rules occur on how your time changes with respect to the "stationary" reference frame.
Einstein's theory is correct. You are not.
Zz.
This is also wrong. The fundamental rule of relativity is that light has the same speed in all frames of reference. Light has not trouble catching up to you because it is catching up to you to you with "the speed of light" just as if you were stationary.
In fact, It makes no sense at all to say you were "stationary" or moving except relative to some given frame of reference- that's why it is called "relativity".
I would suggest that before you assert that relativity is wrong, you at least learn the basics of relativity.
This is practically an exact description of some of the material presented in the Einstein biography on the History Channel. It is totally bogus, and punctuates the PhysicsForums warning about not believing everything you see presented in the popular media. There are other incorrect excerpts in this same video as well, including a well-known physics professor (Michio Kaku) saying that gravity does not pull on an object in free fall, it pushes on it. I don't know what could possibly have motivated him to say this. Part of the reason I studied relativity was so that I could discriminate between what is true and what is bull when I watch TV programs like this.
Chet
As already mentioned, it's all quite wrong. To elaborate:
You are referring to comparisons at constant speed, and what is claimed is that the faster you go, the slower your proper time progresses according to the "rest system" relative to which you are moving.
In order to determine the clock rate of a co-moving clock, you can either use another co-moving clock - which will show nothing different! - or you can use clocks and rulers of the reference system in which you were in rest before. I'll pretend/assume that you did the last, for then we can go to the next:
When you reach speed nearly that the speed of light, it seems that clock is almost still, because light can't catch up to you. Now imagine you stop. What happens? The light catches you and the time seems to flow faster than normal. [..] The speed doesn't effect the time flow. Clock is only a tool to measure time.
"because"?? Light rays that happen to be chasing you, cannot cause your clock to stand almost still! And similarly when you stop. (I also omitted a sentence of which I could make no sense to me at all). Sure a clock is only a tool to measure time, and it sounds as if you confound the Doppler effect with time dilation - but don't worry, that's a common beginners mistake. :smile:
The Doppler effect is explained here:
http://en.wikipedia.org/wiki/Doppler_effect
I didn't mean to say that line can't catch up to you. I meant that if you move for example at c-1km/h, the light takes more time to travel than the situation when you are standing still.
No. That would imply a variable speed of light. The entire point of SR is to integrate a constant speed of light with the principle of relativity.
You need to start over from scratch and learn what SR says. Everything you think you know about it is wrong.
That's irrelevant - see my post #5 in which I tried to explain that. "Special relativistic" effects such as time dilation are in addition to the classical effects to which you refer here.
Most important thing my teacher told me about special relativity: the seemingly 'abnormal' effects of relativity are NOT a result of not taking into account the delay of light reaching you.
In the frame of the clock, emitting light. But not in your frame.
Special relativity modifies space and time in many different ways. If you keep track of all of them, you get consistent physics. If you pick one of them and neglect (or do not know) the others, you get wrong results.
Maybe if you could actually try your experiment, you might think you were right because after traveling at a high speed away from the other clock and then stopping, the other clock would read a much earlier time than your own, as you say, but then what do you think would happen if you came back to the other clock at a high speed? Of course you would see it ticking faster than your clock, but how do you think your two clocks would compare when you finally stop at the other clock?
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 18 ·
  • · Replies 35 ·
