Independence Test Homework Problem Solution
  • Context: Undergrad
  • Thread starter Thread starter EvLer
    Independence Test
The discussion revolves around a homework problem concerning the independence of three vectors represented as matrices. Participants explore the process of testing for linear independence through matrix manipulation and row reduction techniques.
  • Homework-related
  • One participant presents a problem involving three matrices and seeks assistance in determining their independence.
  • Another participant questions the method used to arrive at the matrix form and suggests an alternative row reduction process.
  • A third participant clarifies the equations derived from the dependence condition and presents the augmented matrix for analysis.
  • Subsequent replies highlight the implications of the equations, suggesting that if certain variables must equal zero, the vectors may indeed be independent.
There is no consensus on the independence of the vectors, as participants present differing interpretations of the row reduction process and the implications of the resulting equations.
Participants express uncertainty regarding the row reduction steps and the interpretation of the resulting equations, indicating potential limitations in their understanding of linear independence tests.
Students or individuals studying linear algebra, particularly those interested in understanding vector independence and matrix manipulation techniques.
EvLer
Hello,
I have a homework problem I need some help with.
Given 3 matrices:
A = [1,2,1,2]^t
B = [2,3,-1,0]^t
C = [1,0,1,0]^t
I need to use test of independence to find out whether they are independent.
So, the matrix I ended up with is this
1 2 1 0
0 1 2 0
0 0 0 0
0 0 0 0
The answer says it's independent and I can see that from the original matrices. But I do not know how to proceed with the indep. test to prove that; for one thing, I have more equations than unknowns (I know they are all zeros, so I just disregarded the last row) and for another, if I make it a row-echelon form it looks like column 3 (not being a pivot matrix) is actually a lin. comb. of col.1 and 2 which means that the set is lin.dep.
Where did I go wrong?
Thanks.
How did you end with that matrix?
Using the given vectors as rows of a matrix, you start with
1 2 1 2
2 3 -1 0
1 0 1 0
Now "row reduce":
subtract twice the first row from the second row and subtract the first row from the third row to get
1 2 1 2
0 -1 -3 -4
0 -2 0 -2
Now subtract twice the second row from the third row:
1 2 1 2
0 -1 -3 -4
0 0 -6 6
Look independent to me!
well, since they are transposes (I put '^t' there), following the dependence equation I got initially this:
xA+yB+zD = 0 (vector, i.e. zero vector 4 by 1)
which is
1x + 2y + z = 0
2x + 3y + 0 = 0
1x - y + z = 0
2x + 0 + 0 = 0
and then I got the augmented matrix which reduced to what I posted above and I cannot 'make' it independent.
Thank you for reply.
Take a look at your last equation: 2x= 0. Doesn't that say that x= 0? Now put that back into the second equation: 3y= 0. y must be 0! finally, either of the remaining equations and you get z= 0. Looks independent to me!
That obvious...
Thank you very much.
  • · Replies 23 ·
  • · Replies 0 ·
